remote desktop connection problem for SP3
Discussion in 'Windows XP' started by kevinwang, 2009/06/15.
  1. 2009/06/15
    kevinwang
    kevinwang Inactive Thread Starter
    recently ,i have installed windows sp3 on my computer ,but now i am not to able to open the remote desktop connection,i have got the message for prompt details as following :
    the pre-release version of remote desktop connection has expried to download the full version of remote desktop connection go to windows updtae or contact your system administrator.
    the file of SP3 size 336M that i have download from internet and the name is windowsxp-kb936929-sp3-x86-enu
    how to remove the SP3 from my computer or how to fix this problem
    thanks
  2. 2009/06/15
    You can copy the previous version of the following two files into your \Windows\System32 folder:
    mstscax.dll
    mstsc.exe
    You can copy these files from another pre-SP3 XP machine or simply search your local hard drive and use a previous version which will be in a previous $NtServicePackUninstall$ folder or in the DLLCACHE folder.
    Then execute the mstsc.exe.
    kevinwang
    i have tired as your way before i have release the problem on bbs forum when i copied the two old files into system32\ folder that the old file of mstsc.exe will be change automatic to new version,so can not be open also
    the problem has been resolved until i have reinstalled other SP3 version on my computer
    currect size of SP3 is 316MB and the file version is 6.2.29.0
    anyway thanks for your information and reply timely
