Resolved Remote Desktop--concurrent connections?
Discussion in 'Windows 7' started by elcajongunsfan, 2015/03/04.
  1. 2015/03/04
    elcajongunsfan Lifetime Subscriber
    elcajongunsfan Well-Known Member Thread Starter
    I looked around the internet but am not sure about this.. Can you have several concurrent connections into a Win 7 Pro machine or does the platform only allow one?
    Thanks all
  2. 2015/03/04
    AFAIK consumer versions of Windows (XP/Vista/7/8) allow only one remote desktop connection. The server editions however allow unlimited connections (depending on the version & licences).
    One is the default number for Win7 Pro... Zero is the number for 7 Home...
    Here's a patch/fix/tweak to change the number to two on 7 pro.
    http://www.serverwatch.com/server-t...rrent-remote-desktop-sessions-in-windows.html
    I did this tweak a while back on an XP machine....
    On server editions, the default number is two connections... But you can purchase Terminal Server CAL's at about $85.00 USD per user. (have to purchase in grups of five)
  5. 2015/03/05
    Yeah, after I posted I found that info. I also found that there is a possibility that if you run that patch, one could be violating Microsoft EULA--especially if used in a business environment
    Thanks all
