Remote Deskop Trunkating reports
Discussion in 'Windows XP' started by stevenede, 2009/11/30.
  1. 2009/11/30
    stevenede
    stevenede Inactive Thread Starter
    I have a strange issue here! I am using Remote Desktop to run an application in another country. Everything is fine untill i run reports. I can view the full report over RD but when i print or print to file the report gets trunkated and only half the report is printed or printed to file.
    Does anyone have any ideas:confused::confused:
  2. 2009/11/30
    amdace
    amdace Inactive
    Can you successfuly print to a printer attached to the remote host?
    stevenede
    Yes i can print.
  5. 2009/12/01
    amdace
    amdace Inactive
    From my previous post I wanted to add, can you print the full report to the printer on the remote host.
    Do you have the same print driver and revision level on the local and remote hosts?
