Remote control
Discussion in 'Windows XP' started by Nihaojs, 2002/02/07.
  1. 2002/02/07
    Nihaojs
    Nihaojs Guest Thread Starter
    I installed remote control function in my xp and tried to use it to control another pc in my private network. It seems to be not functioning. Are there any people know how to set two machine in order to use this function. The second PC uses win 98 se OP. Two PCs are connected with hub. The network and internet and files sharing are ok. Thanks
  2. 2002/02/07
    Hulka
    Hulka Inactive
    The Remote Control application in Windows XP only works with other Windows XP workstations. You cannot control a Windows 98 SE workstation from XP. Check out AT&T's VNC. It's free and works like a charm.
