Registry problems ?
Discussion in 'Malware and Virus Removal Archive' started by zism, 2004/11/19.
  1. 2004/11/19
    zism
    zism Inactive Thread Starter
    When starting up my PC I get several messages (8 to be precise!) stating the following:
    Could not load or run XXXX specified in the registry. Make sure the file exists on your computer or remove the reference from the registry.
    Windows cannot find XXXX. Make sure your typed the name correcty and then try again.
    The XXXX's appear as chinese type looking characters! I cant notice any obvious problems but I am concerned as I know the registry is important to your PC and that you should not touch it!
    Anyone have any ideas what this is and how I can solve it? :confused:
    zism :p
    zism,
  2. 2004/11/19
    Paul
    Paul Inactive
    Welcome to the BBS zism. :)
    Registry errors possibly due to a failed or incorrect uninstall. In my sig. I'd suggest downloading EasyCleaner and Regseeker and run both to clean out some debry from your registry. Use the Unnescessary files cleaner in EasyCleaner as well.
    Run an up to date full virus scan.
    Also from my sig. download Ad-aware and Spybot. Update both programmes and then let both (one at a time) do full scans of your system, and delete all that they find. Use the immunize feature of spybot as well. Update and use these programmes every week or two.
    I'd do full virus and spyware scans before cleaning the registry as suggested above.
    If the registry error was very serious XP should have attempted a repair or load a backup version. So your problem is probably a programme install/uninstall error.
    Paul,
    zism
    Thanks for this Paul. Although it hasnt solved my problem it has freed up 2GB from my PC :p
    Any other suggestions?
    zism ;)
    zism,
    surferdude2
    surferdude2 Inactive
    Yes, get HiJackThis and run the scan. Analyze the results to see where the program is being called from and how it can be deleted.
    http://mjc1.com/mirror/hjt/
  6. 2004/11/21
    Abraxas
    Abraxas Inactive
    Have you installed the Input Method Editors (IME's) for any other languages? These occasionally cause this type of problem with indecipherable characters.
    Install Startup Control Panel and look for IME's starting. If you don't need them, you can disable or remove them from the startup.
  7. 2004/11/21
    zism
    Thanks guys. I ran Hijackthis and this is the report I got - any ideas what I should do now? THis is all liek a foreign language to me!
    Cheers ;)
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://g.msn.co.uk/0SEENGB/SAOS01
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://red.clientapps.yahoo.com/cus.../*http://www.yahoo.com/ext/search/search.html
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
    F3 - REG:win.ini: load=???
    F3 - REG:win.ini: run=???
    F2 - REG:system.ini: UserInit=C:\WINNT\system32\Userinit.exe
    O2 - BHO: Yahoo! Companion BHO - {02478D38-C3F9-4efb-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Common\ycomp5_2_3_0.dll
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
    O2 - BHO: CCHelper - {0CF0B8EE-6596-11D5-A98E-0003470BB48E} - C:\Program Files\Panicware\Pop-Up Stopper\CCHelper.dll
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar_en_2.0.111-big.dll
    O3 - Toolbar: &Yahoo! Companion - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Common\ycomp5_2_3_0.dll
    O3 - Toolbar: MSN Toolbar - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\MSN Toolbar\01.01.1629.0\en-gb\msntb.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar_en_2.0.111-big.dll
    O3 - Toolbar: Pop-Up Stopper &Companion - {8F05B1A8-9D77-4B8F-AF54-6B2202066F95} - C:\Program Files\Panicware\Pop-Up Stopper Companion\popupus.dll
    O3 - Toolbar: Pa&nicware Pop-Up Stopper - {7E82235C-F31E-46CB-AF9F-1ADD94C585FF} - C:\Program Files\Panicware\Pop-Up Stopper\pstopper.dll
    O4 - HKLM\..\Run: [websx] C:\Program Files\websx\int113777.exe -auto
    O4 - HKLM\..\Run: [TaskMates] c:\program files\taskmates\taskmates.exe
    O4 - HKLM\..\Run: [Synchronization Manager] mobsync.exe /logon
    O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINNT\System32\IME\TINTLGNT\TINTSETP.EXE /SYNC
    O4 - HKLM\..\Run: [PHIME2002A] C:\WINNT\System32\IME\TINTLGNT\TINTSETP.EXE /IMEName
    O4 - HKLM\..\Run: [OSS] c:\winnt\system32\ossproxy.exe -boot
    O4 - HKLM\..\Run: [MediaFace Integration] C:\Program Files\Fellowes\MediaFACE 4.0\SetHook.exe
    O4 - HKLM\..\Run: [LoadQM] loadqm.exe
    O4 - HKLM\..\Run: [IMJPMIG8.1] C:\WINNT\IME\imjp8_1\IMJPMIG.EXE /Spoil /RemAdvDef /Migration32
    O4 - HKLM\..\Run: [FLMOFFICE4DMOUSE] C:\Program Files\Office mouse\1.1\moffice.exe
    O4 - HKLM\..\Run: [AdaptecDirectCD] C:\Program Files\Adaptec\Easy CD Creator 5\DirectCD\DirectCD.exe
    O4 - HKLM\..\Run: [EPSON Stylus C42 Series] C:\WINNT\System32\spool\DRIVERS\W32X86\3\E_S10IC2.EXE /P23 "EPSON Stylus C42 Series" /O6 "USB001" /M "Stylus C42 "
    O4 - HKLM\..\Run: [SiSUSBRG] C:\WINNT\SiSUSBrg.exe
    O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
    O4 - HKCU\..\Run: [Yahoo! Pager] C:\Program Files\Yahoo!\Messenger\ypager.exe -quiet
    O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINNT\system32\ctfmon.exe
    O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
    O4 - Startup: ERUNT AutoBackup.lnk = C:\Program Files\ERUNT\AUTOBACK.EXE
    O4 - Startup: Reboot.exe
    O4 - Startup: TalkingBuddy.lnk = C:\Program Files\TalkingBuddy\tbdemo.htm
    O4 - Global Startup: blueyonder Instant Support Tool.lnk = C:\Program Files\blueyonder IST\bin\matcli.exe
    O4 - Global Startup: EPSON CardMonitor.lnk = C:\Program Files\EPSON\EPSON CardMonitor\EPSON CardMonitor1.1.exe
    O4 - Global Startup: LimeWire 4.0.8.lnk = C:\Program Files\LimeWire\LimeWire 4.0.8\LimeWire.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
    O4 - Global Startup: WinZip Quick Pick.lnk = C:\Program Files\WinZip\WZQKPICK.EXE
    O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar_en_2.0.111-big.dll/cmsearch.html
    O8 - Extra context menu item: Backward &Links - res://c:\program files\google\GoogleToolbar_en_2.0.111-big.dll/cmbacklinks.html
    O8 - Extra context menu item: Cac&hed Snapshot of Page - res://c:\program files\google\GoogleToolbar_en_2.0.111-big.dll/cmcache.html
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
    O8 - Extra context menu item: Si&milar Pages - res://c:\program files\google\GoogleToolbar_en_2.0.111-big.dll/cmsimilar.html
    O8 - Extra context menu item: Translate into English - res://c:\program files\google\GoogleToolbar_en_2.0.111-big.dll/cmtrans.html
    O8 - Extra context menu item: Yahoo! Dictionary - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
    O8 - Extra context menu item: Yahoo! Search - file:///C:\Program Files\Yahoo!\Common/ycsrch.htm
    O9 - Extra button: Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\Program Files\Yahoo!\Messenger\yhexbmes0411.dll
    O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {4528BBE0-4E08-11D5-AD55-00010333D0AD} - C:\Program Files\Yahoo!\Messenger\yhexbmes0411.dll
    O9 - Extra button: DesktopUpdate - {76DD9E77-F06C-4471-AB6C-CF03C5C6B5B0} - (no file)
    O12 - Plugin for .pdf: C:\Program Files\Internet Explorer\PLUGINS\nppdf32.dll
    O16 - DPF: Yahoo! Chat - http://us.chat1.yimg.com/us.yimg.com/i/chat/applet/c381/chat.cab
    O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
    O16 - DPF: {15AD4789-CDB4-47E1-A9DA-992EE8E6BAD6} - http://public.windupdates.com/get_f...e08139a2080b:c7857c068f27d7cc50f91b20c15a3e0e
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.c...ls/en/x86/client/wuweb_site.cab?1097407382345
    O16 - DPF: {79B96C72-C0D0-4DC8-BC7E-9F314A918228} - http://imgfarm.com/images/nocache/myspeedbar/myinitialsetup1.0.0.3.cab
    O16 - DPF: {88C51E90-8E9C-4C96-8A45-574D88B63FAF} - http://acceso.masminutos.com/laaplicacion.cab
    O16 - DPF: {88D758A3-D33B-45FD-91E3-67749B4057FA} (Sinstaller Class) - http://dm.screensavers.com/dm/installers/si/1/sinstaller.cab
    O16 - DPF: {8EDAD21C-3584-4E66-A8AB-EB0E5584767D} - http://toolbar.google.com/data/GoogleActivate.cab
    O16 - DPF: {9732FB42-C321-11D1-836F-00A0C993F125} (mhLabel Class) - http://www.pcpitstop.com/mhLbl.cab
    O16 - DPF: {A17E30C4-A9BA-11D4-8673-60DB54C10000} (YahooYMailTo Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/yse/ymmapi_416.dll
    O16 - DPF: {C56CE781-A6FC-4706-8B32-6EB4622155DF} (MediaConnect Control) - http://plugin.euro-infomedia.com/mpv0.cab
    O16 - DPF: {EF99BD32-C1FB-11D2-892F-0090271D4F88} (&Yahoo! Companion) - http://us.dl1.yimg.com/download.companion.yahoo.com/dl/toolbar/yiebio5_1_6_0.cab
    zism,
    #6
  8. 2004/11/21
    surferdude2
    This isn't my baliwick (area of least ignorance) but I'd tag these two for removal while waiting for someone with more insight:
    Alternately, you can go right to the win.ini file, open it, and delete the run= and load= lines. XP does not use those lines to load things although some legacy proggy might. Some Spyware might too.
  9. 2004/11/23
    zism
    thanks surferdude2 you are a star it worked! :p
    zism ;)
    zism,
    #8
  10. 2004/11/23
    zism - you still have some stuff showing up that indicates more problems. We need to see a new Hijackthis log but make sure you have version 1.98.2 and if not, download it and replace the one you have now.
    Also, there should be quite a bit more in the HJT log file and you need to post all of it.
    I'm moving this thread to the security/spyware removal section.
    #9
  11. 2004/11/24
    zism
    Thanks for that Newt. I have run Hijack This again and listed below is the new log I received.
    zism :confused:
    Logfile of HijackThis v1.98.2
    Scan saved at 21:12:37, on 11/24/2004
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    C:\WINNT\System32\smss.exe
    C:\WINNT\system32\winlogon.exe
    C:\WINNT\system32\services.exe
    C:\WINNT\system32\lsass.exe
    C:\WINNT\system32\svchost.exe
    C:\WINNT\System32\svchost.exe
    C:\WINNT\Explorer.EXE
    C:\WINNT\system32\spoolsv.exe
    C:\Program Files\Office mouse\1.1\MOUSE32A.DAT
    C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
    C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
    C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe
    C:\PROGRA~1\MICROS~2\Office10\OUTLOOK.EXE
    C:\Program Files\Yahoo!\Messenger\ymsgr_tray.exe
    C:\Documents and Settings\Linzi Smith\My Documents\Unzipped\hijackthis[1]\HijackThis.exe
  12. 2004/11/24
    Well, this one was fun and I'm very glad you posted it. Most times I can simply give a shopping list and say 'remove all of these' but not this time.
    Run HJT again and scan. Then the items with no comment should be removed.
    The items in green are optional. Not bad stuff but all things that you do not need running at startup and that simply add to system sludge by starting processes that you may not need at all. I'd get rid of all the entries - it does nothing except prevent the things from running when you first start the PC.
    The items with detailed comments are yours to deal with as you see fit.
    A baddie and I've seen references to it as part of a stand-alone adult **** site silent dialer and also as part of a remote control trojan. I'd prefer to leave confirmation to one of our malware experts (and that is not me) but take a look at This site that lists removal instructions. Just don't do anything with this one until someone else confirms what it is and how to remove it.
    Part of Nettsetter - a "market research" program intended to track your Internet usage and buying habits. You may have loaded it as a download accelerator which it really IS NOT. More details Here. If you want it, it is not really harmful to the PC but it does add sludge to your system. If you didn't intend to invite it to spy on you, click on Start -> Run and enter "%WinDir%\SYSTEM\NSCheck.exe /uninstall" (where %windir% is the Windows directory - C:\Windows or C:\Winnt) followed by enter - this removes all registry entries and a box appears saying "uninstall successful. Find and delete the files nscheck.exe, ossproxy.exe.rvt & ossproxy.exe
    What Microsoft Says
    What Others Say
    Not malware but maybe sludgeware so based on the links, decide if you want it running at startup or not
    SiS USB Registry Patch File - fixes the undetectable problem with SiS USB controller on Windows XP. Not sure why you need it running at every startup though. Once a patch is applied, I'd think you'd be done with it. This is another one I'd like a 2nd opinion on.
    Really not sure about this one.
    Supposed to be part of CoolMP3 which I would not want and appears to be busted anyway so I'd remove it.
    These 016 items could all be fine but given the other issues, chances are that at least one is a baddie and I'm too lazy to search. I'd remove them all since any legit ones will be added back the next time you visit a site that needs them so the only effect of removal will be a slight slowing of your next connection while a new .cab file is loaded.
    O16 - DPF: Yahoo! Chat - http://us.chat1.yimg.com/us.yimg.co...t/c381/chat.cab
    O16 - DPF: {15AD4789-CDB4-47E1-A9DA-992EE8E6BAD6} - http://public.windupdates.com/get_f...0f91b20c15a3e0e
    O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.c...b?1097407382345
    O16 - DPF: {79B96C72-C0D0-4DC8-BC7E-9F314A918228} - http://imgfarm.com/images/nocache/m...etup1.0.0.3.cab
    O16 - DPF: {88D758A3-D33B-45FD-91E3-67749B4057FA} (Sinstaller Class) - http://dm.screensavers.com/dm/insta.../sinstaller.cab
    O16 - DPF: {A17E30C4-A9BA-11D4-8673-60DB54C10000} (YahooYMailTo Class) - http://us.dl1.yimg.com/download.yah.../ymmapi_416.dll
    O16 - DPF: {EF99BD32-C1FB-11D2-892F-0090271D4F88} (&Yahoo! Companion) - http://us.dl1.yimg.com/download.com...ebio5_1_6_0.cab
  13. 2004/11/24
    noahdfear
    noahdfear Inactive
  14. 2004/11/24
    noahdfear
    noahdfear Inactive
    Remove it per the instructions on the link given.
    Reboot.exe is not generally a valid file or app for XP. Did you install it?. Search for the file and check it's properties. Give us as much info about it as possible.
  15. 2004/11/25
    zism
    Thanks for all the help and advice. Have made the recommended changes and have run again and this is what I now get:
    Reboot.exe I found was: C:\WINNT\PREFETCH\reboot.exe-26422ADG.pf
    So all I need now (I think!) is advice on the highlighted in red ones (as per NEWT's advice) :
    Scan saved at 18:35:12, on 11/25/2004
    C:\Program Files\blueyonder IST\bin\mpbtn.exe
    C:\Program Files\Yahoo!\Messenger\YPager.exe
  16. 2004/11/25
    Did you follow all the instructions at the site (linked in that bit above) to remove the websx dialer?
    I'd just run HJT and check the registry entry for removal. The patch stuff will still be there but it just won't be running at startup. If it causes USB problems later, easy enough to put the entry back into the registry but I seriously doubt that will be needed.
  17. 2004/11/25
    Lonny Jones
    Lonny Jones Inactive Alumni
    Im not sure so would leave it be
    This is what I would fix)(while all browsers are closed) :)
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://red.clientapps.yahoo.com/cus...rch/search.html
    Restart the PC for those changes to take affect
    disable windows messenger
    Shoot The Messenger http://grc.com/stm/shootthemessenger.htm
  18. 2004/11/26
    zism
    noahdfear
    noahdfear Inactive
    You should print this out and/or save it to text where you can access it in safe mode. If you save to text you can copy/paste the below filenames in the search window. ;)
    Download and save the attached text file to your desktop. Right click and rename to ALRem.reg
    Scan with HJT and fix this entry.
    Double click the ALRem.rg file to merge into the registry.
    Right click My Computer and choose properties. On system restore tab, check the box to turn off. OK out.
    Go to start>run and type msconfig, hit enter. On the boot.ini tab, check the box next to /safeboot and OK. Yes to restart. This will restart your computer in safe mode. Logon to you user account.
    Now in safe mode, you will need to show hidden files and folders, as well as system files.
    Do a search of C: drive and delete the following files if found.
    _iu14d2n.tmp-065eaffd.pf
    6.26.2004.10.53.33....0.reg
    6.26.2004.10.53.34....1.dat
    6.26.2004.10.53.34....1.reg
    aconti.exe-105d3294.pf
    alb.exe-01f9e69e.pf
    alb.exe-0e801625.pf
    alb.exe-0fe358f0.pf
    alb.exe-328f3713.pf
    antilamer light.txt
    backdoor.antilam.13.a.exe-3ab6a254.pf
    backdoor.antilam.20.j.exe-25e4239f.pf
    collecteddata_127.xml
    collecteddata_196.xml
    collecteddata_200.xml
    collecteddata_202.xml
    collecteddata_210.xml
    collecteddata_218.xml
    config.exe
    config.exe-0b915f83.pf
    config.exe-28993197.pf
    drwtsn32.exe-2b4b52ac.pf
    edit.dll
    editsrv.exe
    editsrv.exe-020c4fa9.pf
    edtsrv.exe-34c94755.pf
    edtsrv.exe-3861317c.pf
    edtsrv.exe-39d44f73.pf
    edtsrv.exe-3af77064.pf
    english.reg
    int327777.exe-22f4e5c7.pf
    int327777.exe-317926e6.pf
    int327777.sdb
    joiner.exe-37b4e594.pf
    new_alb.exe-080f644e.pf
    runw.exe
    runw.exe-0acf03f1.pf
    server.exe
    server.exe-04168f44.pf
    server.exe-19885956.pf
    server.exe-1e8ebe0c.pf
    server.exe-1ea17666.pf
    server.exe-1fb68265.pf
    server.exe-1ff20139.pf
    smt.exe-245bb5ee.pf
    trojan.exe-0c7fe615.pf
    trojan.psw.allight.10.b
    trojan1.exe
    trojan1.exe-007581cd.pf
    trojan1.exe-0d8b60b3.pf
    trojan2.exe
    trojan2.exe-12ee91de.pf
    trojan2.exe-2c402d8d.pf
    unins000.exe-1da47506.pf
    websx.dlg
    Open the following directories and delete the files/folder noted.
    C:\Windows\System32\runwin32.exe
    C:\Windows\system\runwin.exe
    C:\Windows\system\runwindows32.exe
    c:\documents and settings\administrator\desktop\5-1-14-24.lnk
    c:\documents and settings\administrator\start menu\5-1-14-24.lnk
    c:\documents and settings\administrator\start menu\programs\5-1-14-24.lnk
    Open C:\Temp if present, select all and delete.
    Open C:\Windows\Temp, select all and delete.
    Open C:\Documents and settings\username\Local Settings\temp, select all and delete. Do this for all usernames.
    Open C:\Windows\Prefetch, select all and delete.
    Open My Computer, right click Local disk C: and choose properties, then disk cleanup. Check all boxes except compress old files and OK.
    Uncheck the /safeboot box in msconfig and ok to reboot.
    Back in Windows, you can re-enable system restore. Run another HijackThis scan and post the log.
  20. 2004/11/30
    zism
    Thanks noahdfear
    sorry I have a few questions! :confused:
    what attached text file?
    where is this file?
    how do I get into safe mode and how do I get out?
    thanks once again
    zism :p
  21. 2004/11/30
    noahdfear
    noahdfear Inactive
    No need to apologize. :)
    At the bottom of my last posting, just above my signature, you will see an 'Attached Files' quote box. Click the ALRem.txt link and choose save. In the opening save dialog box, click 'Desktop' in the left pane then click save.
    ALRem.rg is a typo. I was referrring to ALRem.reg, the text file that you are to download and rename.
    Just follow the instructions given above;
    To get into safe mode
    To get out of safe mode
