Registry Edit Help Needed
Discussion in 'Legacy Windows' started by Steve R Jones, 2002/03/03.
  1. 2002/03/03
    Steve R Jones SuperGeek Staff Thread Starter
    Regisrty Edit Help Needed
    I have the exact problem as outlined in this article. One option suggest I run Installer Cleanup Utility. This didn't help.
    OL2000: Cannot Reinstall Outlook 2000 After Upgrading to Windows 2000 Professional (Q308602)
    The other solution is to do the following:
    Locate the transform value under the following key in the registry, where Current_User is your user ID:
    HKEY_ Current_User \Software\Microsoft\Installer\Products\{GUID}
    On the Edit menu, click Delete .
    I have five folders under HKEY_ Current_User \Software\Microsoft\Installer\Products. Two of them are the office cd's. I'm not sure if I should zap the whole folder or just the "transform" value within the folders.
  2. 2002/03/03
    Guess if I can't spell registry I shouldn't be messing with it.:D
    Problem solved. I "renamed" the transform value and it solved the problem.
    Not too bad only having one problem after upgrading from WinME.
    Steve - glad it worked and thanx for the feedback.
