Red cross over my hard drive in my computer
Discussion in 'Windows XP' started by mrchrismckay, 2008/01/31.
  1. 2008/01/31
    mrchrismckay
    mrchrismckay Inactive Thread Starter
    ok, i had a bad reformatting week, but ive finally survived it, windows xp is back up and running after this that and the other, only one thing remains......
    a red cross over my hard drive in my computer.
    anyone any ideas, i have cleaned the registry, removed spyware etc etc, but nothing. it doesnt do anything, doesnt move, talk, nothing, just sits there!!!!
    help!!!
    anyone???
  2. 2008/01/31
    Are you saying that the hard drive icon is not the usual hard disk, but either that icon or another with a red x on it or .....?
    mrchrismckay
    Everything is normal, the only thing that is different or affected is that the icon has changed when i click open my computer, its not a big deal, at least i think, but i just want to get it back to normal!!!!!so instead of the usual c drive icon, its this big fat red X.
  5. 2008/01/31
    There's a variant of the Vundo virus that causes the drive icon to have a red x. You mentioned "removed spyware ". Suggest posting in the removing spyware forum.
  6. 2008/01/31
    noahdfear
    noahdfear Inactive
    I agree with TonyT that you should pay a visit to the malware removal forum, but here's a fix for your icon. It's usually caused by someone/something attempting to customise the icon. The following registry fix will remove the non-default key where the customization takes place, allowing the default icon to be restored.
    Highlight and copy the contents of the quote box below to a blank notepad. Save it to the desktop as;
    Filename: fix.reg
    Save as type: All Files (*.*)
    Double click fix.reg and allow it to merge with the registry. If the icon is still present when you open My Computer, restart the computer.
