Recycle Bin!
Discussion in 'Windows XP' started by Will, 2003/01/23.
  1. 2003/01/23
    Will
    Will Inactive Thread Starter
    :mad: Following the suggestion of a co-worker, I used a trial version of Evidence Eliminator and decided that I had no real need for the program. I used the uninstall and then deleted all remnants that I could find using windows search, however there is still a menu option when right-clicking the Recycle Bin, "Evidence Eliminator Protected Recycle Bin ". My co-worker says to just ignore it, but I would prefer to repair it. I would rather not re-install for this if at all possible. System specs are:
    Amd - 950/640 megs sdram/Windows XP Home SP1
    Please advise.....
    Will,
  2. 2003/01/23
    reboot
    reboot Inactive
    You'll have to edit the registry to eliminate the right click stuff.
    Just open regedit, and do a search for "Evidence Eliminator ".
    Zephyr
    Zephyr Inactive
    If you don't find it with the search, take a look in the Registry at HKEY_CLASSES_ROOT\Folder\shellex\ContextMenu Handlers. That seems to be where they reside.
  5. 2003/02/09
    Will
    Oh, Well
    Followed suggestions, to no avail.... But as it happens, I was suprised by the little lady with a new HD and decided to back-up everything and start fresh.......
    Thanks for the input........
    Will,
