Recycle Bin
Discussion in 'Legacy Windows' started by Christer, 2003/01/10.
  1. 2003/01/10
    Christer
    Hello all!
    I copy my documents folder to my D: every now and then as a backup.
    When I remove the previous copy (approx. 300 MB) it goes to the Recycle Bin.
    When I empty the RB it may take a minute or more before the system continues to respond.
    Is this typical of WinME?
    Before anyone asks, yes I have Norton Protected Recycle Bin but it is disabled and set to standard RB.
    TIA,
    Christer
  2. 2003/01/11
    Daizy
    Daizy Inactive
    Hi Christer
    I'm going to go out on a limb and say yes.... "It's normal. ". On two of my machines running Windows ME, when emptying a large amount from the recycle bin, the computer lags until it finishes.
    Daizy
    Christer
    Hello Daizy,
    thanks for Your reply!
    The first few times I thought it was freezing and I tried to close Windows but exercising some patienience will let it resume normal response.
    Christer
  5. 2003/01/12
    Daizy
    Daizy Inactive
    Hi again Christer.
    So long as you're not getting any error messages, I'd assume all is well.
    Daizy
