Recycle bin won't empty
Discussion in 'Legacy Windows' started by BlahGuert, 2005/01/08.
  1. 2005/01/08
    BlahGuert
    BlahGuert Inactive Thread Starter
    ok........my problem is almost the same as one that i was reading a min ago about a recycle bin that shows full but isnt. It says that it is full but when i empty it it just says "are you sure you want to delete all the files blah blah..." and i say yes and thats it, but it is still showing full and it is soo frustating!!! :mad: any help would be apreciated. thnx
  2. 2005/01/15
    Try clicking on start=>run, keying in cmd and from the cmd prompt
    [/b]chkdsk /r[/b] and answer to have the chkdsk run at next boot then reboot. If the files are still there and still won't go away, boot to safe mode and try from there.
