Recycle Bin Icon disappeared
Discussion in 'Legacy Windows' started by bthomas, 2003/01/23.
  1. 2003/01/23
    bthomas
    bthomas Inactive Thread Starter
    I have Windows 98 and the Recycle Bin Icon has disappeared. How do I get it back?
  2. 2003/01/23
    goddez1
    goddez1 Inactive
    Have you tried an autoarrange just to make sure it isn't playing hide_N_ go_seek off screen or behind another icon???
    If it turns out not to be as simple as this I got a google bbs link that has some other ideas you try:
    http://www.experts-exchange.com/Operating_Systems/Win98/Q_20207093.html
    If none of these pan out just let me know and we can move on to the other problems that may cause this.
    BOBBO
    BOBBO Geek Member
    bthomas: If you have TweakUI, open it and then click on Desktop. Recycle Bin should be in the list to the right. See if the box is checked. If it isn't, click on the box to put a checkmark in it, click on OK and close TweakUI. Your Recycle Bin icon should reappear.
  5. 2003/01/24
    merlin
    merlin Inactive
    restart in msdos mode
    type deltree /y C:\recycle~1
    reboot (ctrl+alt+del)
    regards
  6. 2003/01/26
    merlin
    merlin Inactive
    that should be
    C:\recycled
