Rebooting Problem
Discussion in 'Windows XP' started by roy66, 2006/07/30.
  1. 2006/07/30
    roy66
    roy66 Well-Known Member Thread Starter
    When I click on START to bring up the restart option it just freezes and doesn't change to the option.
    I have to restart by pressing the button on the tower.
    Any ideas please?
    Thankyou
    roy66
  2. 2006/07/31
    roy66
    Thanks a lot and there was a LOT to look through so I put it on the backburner for a while.
    Since then I installed and ran a couple of times Advanced Windows Care from http://www.iobit.com/
    Seems this piece of software sorted out some irregularities and now the problem I had no longer is an issue.
    Previous to this I had downloaded Tray Commander from http://www.ardamax.com/which served the purpose.
    I have included this info for others who might visit this posting.
    Once again THANKS
    roy
