Resolved Realtek audio manager popping up
Discussion in 'Other PC Software' started by Mfink54, 2010/02/10.
  1. 2010/02/10
    Mfink54
    Mfink54 Inactive Thread Starter
    When I click on Mute all on my volume controls the Realteck audio manager pops up and whatever you do it keeps popping back up.
    It only happens on one user account. If you uncheck mute all it stops. Its driving me crazy. Has anyone else come across this? Its a windows xp sp3 machine, 2 gb ram.
  2. 2010/02/10
    kimsland
    kimsland Inactive
    You just need to stop Realtek audio manager from starting with that account
    By selecting mute it therefore shouldn't open
    Open up the Realtek audio manager settings screen and check for 1. Load with Windows and 2. disable popups or dispay settings.
    I generally disable as much as I can from loading with Windows, including hotkeys.
    I just want Windows and security software loading all the rest I can start manually.
    Here's a simple tool that can disable (and subsequently re-enable) Windows startups:
    Startup Control Panel
    Mfink54
    There are no options is the Realtek audio manager to stop it from loading in windows
  5. 2010/02/10
    kimsland
    kimsland Inactive
    In Startup Control Panel, click on HKLM / Run Tab
    Locate RTHDCPL.EXE, then de-select it, then Restart
  6. 2010/02/11
    Mfink54
    I'll try from msconfig, I don't like installing any more apps than I have to. I'll post to let you know
  7. 2010/02/11
    kimsland
    kimsland Inactive
    Mfink54
    I see your point, I had forgotten about msconfig leaving it in Diagnostic mode. I remembered I have Spybot S&D (I've used and trusted this for years) on my computer so I went into advanced mode and removed realtek from startup and my issue is solved. Thank you so much for your input as I've learned from it.
