Range Extender Won't Connect
Discussion in 'Networking (Hardware & Software)' started by RonUK, 2010/04/13.
  1. 2010/04/13
    RonUK
    RonUK Inactive Thread Starter
    Hi all,
    Have a frustrating problem. I am running a Sagem Router (from Sky - not sure of the model). The wireless range is not great so I purchased a Sitecomm WL-330 Range Extender. At first it installed and connected straight away with no problems. I had to disable the wireless capability on the laptop and connect to the extender via Ethernet. All OK until the Sagem hung and I needed to reboot it. Since then I cannot get the Range Extender to reconnect to the Sagem as it won't assign a new IP address. I didn't need to touch the IP settings first time round and everything is set to assign IP addresses automatically. Any clues?
  2. 2010/04/15
    tomw
    tomw Inactive
    Check the doc for the extender, and find out how to reset it to factory defaults. Do that, and let it find the router and re-assign an IP address. Why does the laptop need to be connected via ethernet cable? Seems to be defeating the purpose of the extender.
    I would think you might need a wired connection for setup purposes, but not for general use. Something seems amiss.
    tom
    tomw,
