Random Crashes when using web browser
Discussion in 'Windows XP' started by donhinio, 2005/12/21.
  1. 2005/12/21
    donhinio
    donhinio Inactive Thread Starter
    Hello All,
    I have a very annoying problem that I cannot fathom, and it is driving me bonkers!:
    Randomly, when using either AOL(version 9) browser or Internet Explorer - my PC crashes. My screen goes black and my base unit does not respond, even to the power button, even though the light is still on. When I reboot my PC, all is fine again and have no error messages. This can happen either once or eight times during a two hour surfing session. It has only happened twice whilst off line.
    I have run Adware removal, spyware removal, virus removal and Registry Mechanic software, but to no avail. It just keeps crashing.
    I am running Windows XP (SP2) on a AMD Athlon 64 - 3400+
    Is it AOL or is it my graphics card (Radeon 9800), or am I just going mad!!!?
    All help very much appretiated, and will stop me from throwing my PC out of the window.....
    Regards,
    Donhinio.
    PS. I live in the UK
  2. 2005/12/21
    donhinio - Welcome to the Board :)
    When you say that you see no error messages on boot up after a crash do you mean on the screen or in Event Viewer?
    To access Event Viewer right click on My Computer icon > Manage > Event Viewer - look in both Application and System for flagged error messages timed to coincide with your screen blackouts. Error messages are flagged with a white cross on a red ground.) Double click on a message to open and on the icon below the up/down arrows to copy to clipboard and paste here if relevant).
    As this happens almost exclusively when you are on line it is possible that the problem lies with the modem driver or the modem itself and it would be worth renstalling the modem driver.
    I doubt it is your video card - you would expect random crashes regardless of whether you were connected to the Internet or not.
    AOL?? Not in a position to comment as I do not use it, but I'm sure you will get some views on this from others.
    oshwyn5
    oshwyn5 Inactive
    Lets approach this from a troubleshooting perspective.
    IF it were the video card freezing; your computer would still respond to input from your keyboard and mouse even though you could not see the result. SO if you were to do the ctrl+alt+del twice or Windows key(to bring up start menu) followed by R then enter it would restart.
    But you mention that the power button on the front has no effect either.
    Now , if the CPU locked up, often you will see the last frame it sent to the video card displayed. The computer appears normal, just frozen. NO response to input from keyboard or mouse. It could still be this, especially if you have onboard video which relies on the CPU (but you do not) . Heat or power instability are common causes of CPU lockup.
    But the power button should still restart it , at least if you hold it down for five seconds to cause the power supply solenoid which is tripped on when you first press the button to trip off.
    What would disable the power button on the front? A bad power supply is most likely. It would also lock things up when it became unstable and the voltage got out of safe range. Although a short (incorrect installation of the motherboard, failure to use two fiber washers one above and one below the board at all mounting points) could also cause these symptoms.
    Since everest is no longer free, I would recommend trying
    Sisoftsandra
    or
    Fresh diagnose
    To check your voltages and make sure that they are not over ten percent variant from the specified value(Less than five percent preferably).
    My question at this point would be what type of connection you have? A dial up modem, a USB connection to a broadband modem , or ethernet?
    USB could also cause short or excessive draw on your 5V rail.
    That it happens more commonly while online may in fact be caused by the increased usage of either the CPU or video card. Both could cause heat issues or power issues.
    I too agree you should check your event log to rule out a driver issue; but really think this is more likely to be hardware related.
  5. 2005/12/24
    apeferreira
    apeferreira Inactive
    Just a silly question: are you sure the CPU fan is OK?
  6. 2005/12/25
    skeet6961
    skeet6961 Inactive
    along the fan lines mentioned, is this system cooled ok? check u'r temps. and the PS is another possible. is u'rs up to snuff on u'r setup? eg - enuff wattage and stable. if u'r overclocking, don't ;)
    re: power button - are u holding it in for 5 secs? or just pushing it once?
  7. 2005/12/26
    donhinio
    Hello All,
    Many thanks for the friendly welcome!
    As a newbie in the fixing PC stakes, can you explain two things for me so I can get a better understanding:
    1) When you talk about the voltage not being correct, what exactly does this mean, and why would the pc be okay for about four months before starting to crash?
    2) I have loaded SiSoftware - Sandra Lite, what do I use to tell me that my voltage is okay?
    Pete C: My computer has not crashed since my first posting, so cannot post the error message here.
    oshwyn5: Since it has not crashed, I have not tried to hold the power button for five seconds yet, and I have a USB broadband connection.
    Many thanks,
    Donhinio.
  8. 2005/12/31
    Sorry for the delay in responding - either I failed to see the notification of your post or it got lost in the Christmas rush :(
    The Power Supply (PSU) provides several different voltages to specific items on the motherboard and these need to be within certain limits for the PC to function correctly. Attached a screenshot from Everest on the voltages measured by the program on my laptop - I am away from home at present. These values are not necessarily typical of a desktop PC as the laptop has a Mobile Intel Celeron, for example. On many computers some, if not all of this information can be found in the BIOS.
    IF the problem is due to a faulty PSU these can fail at any time which would explain why you have had no problems for 4 months.
    I have used this program only infrequently and do not have access to it at present, but, as I recall, there are a number of tests that can be run - one of them will surely show the voltages :)
  9. 2005/12/31
    skeet6961
    skeet6961 Inactive
    as to temps - u'r MB maker should have some util to 'gauge' the temps. install it or use bios to 'see' what they're at. if they're high, u can/should get a HSF (heatsink/fan) that will do a better job cooling it.
    most home built PCs w/ stock HFS are not that great on temps. if the chip gets too hot, it'll freeze or reboot.
    i've seen some pre-builts that come overclocked w/ stock RAM that will run fine on standard apps. once something 'pushes' them - usually a game or such - they blow up ;) ... eg - they're sold as p 4 2.4 but they're really a p4 1.8 w/ the FSB cranked up
    anyway ... re: bios temps - what are they in C? if they're up near/above 70c ... it's too hot ... much nicer to be down near 45c or so
  10. 2005/12/31
    Have you updated Windows ? Firewall ? Can you swap power supply ?
  11. 2006/01/02
    donhinio
    Thanks All for your advice so far...
    I have pasted below the Sisoftware readout from my system, the 'Temperature Sensor' and 'Voltage Sensor' readings are halfway down, but have also included other readings as they may hold a clue to your trained eyes.
    Is there anything untoward here?
    rsinfo: Yes I do have updated Windows and Norton antivirus and firewall
    Many thanks,
    Donhinio.
    PS. Further to my first post, my PC does re power if I hold the power on button for 5 seconds after a crash.
    SiSoftware Sandra
    System
    Manufacturer : Tiny Computers
    Model : MS-6741
    Version : 1.0
    Serial Number : 00000000
    System Chassis
    Manufacturer : Uknown Chassis Manufacture
    Type : Desktop
    Can be locked : No
    Version : Version 1.00
    Serial Number : 123456890
    Asset Tag : 0123ABC
    Mainboard
    Manufacturer : Time Computers
    MP Support : 1 Processor(s)
    MPS Version : 1.40
    Model : MS-6741
    Version : 1.0
    System BIOS : 63-1108-009999-00101111-040201-VIA
    Memory Controller
    Error Detection Method : ECC
    Error Correction Capability : 1-bit
    Supported/Current Memory Interleave : 1-way / 1-way
    Number of Memory Slots : 2
    Maximum Installable Memory : 2GB
    Maximum Module Size : 1GB
    Supported STD/FPM/(B)EDO Speeds : 70ns, 60ns
    Supported Memory Types : STD, FPM, EDO, Parity, ECC, SIMM
    Supported Memory Voltages : +3.3V
    Physical/BIOS Memory Banks
    DIMM1 (RASL-1 RASL-0) : 512MB DIMM SDRAM single-bank
    DIMM2 (RASL-3 RASL-2) : 512MB DIMM SDRAM single-bank
    Chipset 1
    Model : VIA Technologies Inc K8M400 CPU to PCI Bridge
    Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
    Version : 1.02
    Front Side Bus Speed : 2x 800MHz (1600MHz data rate)
    In/Out Width : 16-bit / 16-bit
    Chipset 1 Hub Interface
    Type : V-Link
    In/Out Width : 4-bit / 4-bit
    Multiplier : 2/1x
    IO Queue Depth : 9 request(s)
    Logical/Chipset 1 Memory Banks
    Power Save Mode : No
    Fixed Hole Present : No
    Chipset 2
    Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
    Version : 1.02
    Maximum FSB Speed / Max Memory Speed : 2x 1000MHz / 2x 200MHz
    IO Queue Depth : 8 request(s)
    Chipset 2 Hub Interface
    Type : HyperTransport
    Version : 1.02
    Logical/Chipset 2 Memory Banks
    Bank 0 : 512MB DDR-SDRAM 2.5-3-3-7 1CMD
    Bank 2 : 512MB DDR-SDRAM 2.5-3-3-7 1CMD
    Channels : 1
    Speed : 2x 160MHz (320MHz data rate)
    Multiplier : 1/15x
    Width : 64-bit
    Refresh Rate : 6.00µs
    APIC 1
    Version : 0.03
    Multiplier : 1/2x
    Maximum Interrupts : 24
    IRQ Handler Engaged : Yes
    Enhanced Support : Yes
    Memory Module 1
    Manufacturer : Kingston
    Model : K
    Serial Number : 53289D54
    Type : 512MB DDR-SDRAM
    Technology : 8x(64Mx8)
    Speed : PC2700U 2.5-3-3-7
    Date of Manufacture : 19 March 2005
    Set Timing @ 167MHz : 2.5-3-3-7
    Set Timing @ 133MHz : 2.0-2-2-6
    Memory Module 2
    Model : K
    Serial Number : 52289754
    Environment Monitor 1
    Model : Winbond W83697(T)HF ISA
    Version : 6.00
    Mainboard Specific Support : No
    Temperature Sensor(s)
    Board Temperature : 45.5°C / 113.9°F
    CPU Temperature : 47.0°C / 116.6°F td
    Cooling Device(s)
    Auto Fan Speed Control : No
    Chassis Fan Speed : 2637rpm
    CPU Fan Speed : 2250rpm
    Voltage Sensor(s)
    CPU Voltage : 1.47V
    +3.3V Voltage : 3.26V
    +5V Voltage : 4.92V
    +12V Voltage : 12.28V
    -12V Voltage : -11.95V
    -5V Voltage : -5.10V
    Standby Voltage : 4.87V
    Battery Voltage : 3.52V
    AGP Bus(es) on Hub 1
    Version : 3.00
    Speed : 8x
    Fast-Writes Enabled : Yes
    Isochronous Mode Enabled : No
    Addressing Enabled : 32-bit
    PCI Bus(es) on Hub 1
    Version : 2.10
    Number of Bridges : 1
    PCI Bus 0 : PCI (1/1x PCIClk)
    LPC Hub Controller 1
    Model : VIA Technologies Inc VT8237 PCI to ISA Bridge
    ACPI Power Management Enabled : Yes
    Delayed Transaction Supported : Yes
    Delayed Transaction Enabled : No
    Multiplier : 1/4x
    DMA Multiplier : 1/2x
    USB Controller 1
    Model : Micro-Star International Co Ltd (MSI) VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
    Version : 1.10
    Interface : UHCI
    Channels : 2
    Speed : 48MHz
    Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
    Legacy Emulation Enabled : No
    USB Controller 2
    Version : 1.10
    Interface : UHCI
    Channels : 2
    Speed : 48MHz
    USB Controller 3
    Version : 1.10
    Interface : UHCI
    Channels : 2
    Speed : 48MHz
    USB Controller 4
    Version : 1.10
    Interface : UHCI
    Channels : 2
    Speed : 48MHz
    USB Controller 5
    Model : Micro-Star International Co Ltd (MSI) VT6202/12 USB 2.0 Enhanced Host Controller
    Version : 2.00
    Specification : 1.00
    Interface : EHCI
    Channels : 8
    Companion Controllers : 4
    Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
    Addressing Support : 32-bit
    FireWire/1394 Controller 1
    Model : Micro-Star International Co Ltd (MSI) VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
    Version : 1.00
    Interface : OHCI
    Enhanced Support : No
    Channels : 64
    Speed : 400MHz
    System SMBus Controller 1
    Model : VIA VT823x SMBus
    Advanced TCO Mode Enabled : No
    Slave Device Enabled : No
    PEC Support : No
    Speed : 16kHz
    Expansion Slot(s)
    PCI1 (1h) : PCI 32-bit +3.3V Shared PME Full-Length Used (VIA Technologies Inc Apollo K8HTB CPU to AGP 2.0/3.0 Bridge)
    PCI2 (2h) : PCI 32-bit +3.3V Shared PME Full-Length Used
    PCI3 (3h) : PCI 32-bit +3.3V Shared PME Full-Length Used
    PCI4 (4h) : PCI 32-bit +3.3V Shared PME Full-Length
    PCI5 (5h) : PCI 32-bit +3.3V Shared PME Full-Length (Micro-Star International Co Ltd (MSI) Ralink RT2500 802.11 CardBus Reference Card)
    ISA1 (6h) : ISA 16-bit +3.3V Shared PME Full-Length
    ISA2 (7h) : ISA 16-bit +3.3V Shared PME Full-Length
    Port Connector
    USB - Def : SSA SCSI - Mini Centronics / DB-25 pin male
    Performance Tips
    Notice 224 : SMBIOS/DMI information may be inaccurate.
    Warning 2507 : Mainboard has too few memory slots. Upgrading the memory may be difficult or expensive.
    Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
    Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
    Tip 2546 : Large memory modules should be ECC/Parity.
    Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
  12. 2006/01/02
    Your voltages look fine so I would not anticipate a problem with the PSU. As a point of interest your CPU voltage is running at maximum - the AMD 64 bit processors can take advantage of AMD's Cool'nQuiet technology which controls the speed at which the CPU runs depending on the applied load. I have an AMD 64 3500+ running Cool'nQuiet and, as you will see from the attached screenshot (from my desktop) it is currently running at ~50% despite the fact that the computer is currently downloading a 2 Gb file.
    I am a little concerned with your motherboard temperature - 45.5 deg C is on the high side IMO - CPU temp is OK especially as it is running at 100% voltage. As a check it would be a good idea to run Everest to cross check these temperatures. I think you said you were on broadband - if you would like to PM me an email address I will send you the latest - and last version of Everest.
    As the crashes occur when using AOL or Internet Explorer I would not think that the browser is to blame. The common denominator here is the modem. Might be worth uninstalling it, rebooting and reinstalling.
  13. 2006/01/02
    donhinio
    It's true that 98% of crashes occur whilst on the internet, but 2% (about four times out of the hundreds of crashes) have been offline.
    Could the modem be responsible for that too?
    Have just sent you PM with email, and will cross reference the temperatures and post them...
    Thanks,
    Donhinio.
  14. 2006/01/02
    The offline crashes may have been for a different reason - without details it is difficult to say. However - on broadband you are always 'on' - whether you have a browser open or not. Simple enough to uninstall and reinstall the modem through Device Manager and the software through Add/Remove programs.
  15. 2006/01/02
    donhinio
    Pete,
    Many thanks for the mail....
    Sensor readings below:
    --------[ Sensor ]------------------------------------------------------------------------------------------------------
    Sensor Properties:
    Sensor Type Winbond W83697HF (ISA 290h)
    Motherboard Name MSI MS-6524 / 6701 / 6741
    Temperatures:
    Motherboard 46 °C (115 °F)
    CPU 58 °C (136 °F)
    Seagate ST3200822AS 47 °C (117 °F)
    Cooling Fans:
    CPU 2557 RPM
    Chassis 2280 RPM
    Voltage Values:
    CPU Core 1.49 V
    Aux 0.03 V
    +3.3 V 3.28 V
    +5 V 4.95 V
    +12 V 12.16 V
    -12 V -12.03 V
    -5 V -5.10 V
    +5 V Standby 4.87 V
    VBAT Battery 3.54 V
    Debug Info F 42 4A FF
    Debug Info T 58 46 255
    Debug Info V 5D 02 CD B8 C8 23 34 (01)
  16. 2006/01/02
    OK, Everest has confirmed the voltages which are fine, but I think that your system cooling leaves a little to be desired - although none of the temps are really excessive, they are just a bit on the high side IMO.
    However, I don't think we should be sidetracked by these temps into thinking that they are the root cause of the problem. However it might be worth running the PC with the side panels removed and monitoring the temps. The PC may well run hotter with the side panels removed in which case put the sides back on :) , but if they are lower what is the effect on the crashes while browsing?
    I still think the modem should be investigated as I posted before as it still seems to me to be the common denominator here.
    Have you checked for updated drivers at the manufacturer's web site?
    Have you accepted an updated modem driver from Windows Update in the recent past?
  17. 2006/01/02
    I forgot to post details of AMD Cool'nQuiet Technology - Personally I would install it if it is compatible with your motherboard and reduce the heat output from the CPU. According to AMD, if your MSI motherboard is the 6741G then Cool'nQuiet is supported. The 6741 does not appear to support it.
  18. 2006/01/03
    oshwyn5
    oshwyn5 Inactive
    Looking over temperatures and voltages I see nothing which would explain a crash. Of course it could be intermittent which would not show until it was about to happen.
    Given the predominance of crashes being when you are online (the others could be when something like an automated update process connected) I would suspect the USB modem. I have heard of many instances where a USB modem caused problems like this which replacing it with an ethernet modem and a router solved. Does this modem support connecting through an ethernet as alternative ? Does it have external power or does it draw all power over the USB? Finally do you have other USB devices?
    My technique for ruling out other causes would be to disconnect the USB modem from the computer and then do something processor intensive such as watch a DVD movie if you have a dvd player, or set the screensaver to one of the more complex ones (3d maze and click settings to the right of it and change wall floor and ceilings to complex colorful and all different , set to full screen ) let it run for a couple hours. Anything else you can think of based on the programs you have to stress things out a bit and see if it crashes.
    If not, it is either your modem or it is spyware infesting your computer.
    Go online and get the programs recommended on the Spyware and malware removal board (Spybot, ad-aware, etc) and run them to make sure you are clean.
    If you come up clean; I would conclude it was the modem.
    PS, in the hands of Pete C and Skeet you are in the hands of two of the best I know. So make sure you did what they suggested before you bother with these steps.
  19. 2006/01/03
    apeferreira
    Hi Donhinio,
    Sorry the delay, I was away... I agree with Petec and, if the crashes still happen, I would suggest to leave your PC on and running a few programs, not connected to the modem. Leave it for a few hours or overnight. That will prove that the problem is not related to the modem nor the Net. Run as many programs as you can to fill the memory, sort of dynamic memory tests. Let us know what happens. If it is OK, try to disable the programs that run in the background during startup (run msconfig and experiment). But again, an intermitently faulty PS may still be the culprit...
    Good luck!
  20. 2006/01/04
    skeet6961
    skeet6961 Inactive
    ah ... u'r da man pete ... how's the hounds?
    to OP - i'm not really current on HW stuff so take all from skeet here w/ grain of salt. stick w/ petec, pete and apeF in this thread
  21. 2006/01/04
    donhinio
    Big thanks to all for your help and advice - it's invaluable!
    I am changing from AOL next week to a new ISP and am getting a new modem with ethernet, so I will wait until then and see if my crashes re occur.
    oshwyn5: System definately clean of spyware.
    Pete C: Sorry to be a baffoon, but which utility should I download from AMD?
    I'll post you again next week and let you know either way as to how I get on.
    Thanks again.:)
    Donhinio.
