Windows Vista Random Crashes DRIVER_IRQL_NOT_LESS_OR_EQUAL yk60x86.sys
Discussion in 'Legacy Windows' started by Paintballparrot, 2008/07/10.
  1. 2008/07/10
    Paintballparrot
    Paintballparrot Inactive Thread Starter
    My laptop has been crashing at random with no discernible pattern except that as far as I can remember Firefox has always been open when it crashes, but Firefox is open 90% of the time on my laptop anyway. (and all the crashes have been DRIVER_IRQL_NOT_LESS_OR_EQUAL yk60x86.sys) This has happened about 10 times since I got the laptop back for service (I'll explain this in a bit) Its happened while I'm playing FFXI, Using Visual Studio 2008, while I'm just surfing the web and once when I unplugged the power cord. (that wiped several drivers and I had to re image)
    I looked up what yk60x86.sys is, Its a driver for my wired LAN Card a Marvell Yukon 88E8071 PCI-E Gigabit Ethernet Connector which is currently disabled via Device Manager. As far as I remember I have never had a crash while the device has been disabled. about 3 weeks ago I had about 5 crashes in 10 hours, after this I found the latest driver for the Network card and installed it. For 2 weeks I had no crashes, then while at a friends I had the crash that wiped out drivers. I re imaged the computer using the Acer eRecovery partition (therefore I do not have any of the previous dumps) and less than 24 hours later I had another crash.
    Now I think a contributing factor may be that 3 months ago I fell down the stairs... with my laptop and cracked the screen. I bought the laptop from Best Buy and accidental damage was covered under the service plan so I had it repaired, while it was going in for service I asked them if they could fix my broken headphone jack which I'm assuming is why the motherboard was replaced (the jack is soldered to the motherboard) after 5 weeks I got it back and returned it the next day due to a dead motherboard. It was sent in for service again and came back 2 weeks later and I had my 1st crash of this type within a month.
    Before I got my laptop back from service I had it for 2 months and never had a crash. I think something may have been damaged at the service center (as the right 1/4 of my touch pad has been dead since I got it back too) if this is a hardware problem would uninstalling the driver fix the problem as I cannot take the laptop back in for service until I have a week off school in August? Losing abaility to plug into LAN is not a problem as I've only used that once or twice.
    Thank you for your help
    This crash was using the driver that came with teh compute from the factory but I've had crashed under the newest version too
    Opened log file 'c:\debuglog.txt'
    Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
    Loading Dump File [C:\Users\Radical Edward\Desktop\Mini070908-01.dmp]
    Executable search path is: C:\Windows;C:\Windows\system32;C:\Windows\system32\drivers
    Windows Vista Kernel Version 6000 MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Built by: 6000.16584.x86fre.vista_gdr.071023-1545
    Kernel base = 0x81c00000 PsLoadedModuleList = 0x81d11e10
    Debug session time: Wed Jul 9 13:59:19.545 2008 (GMT-4)
    System Uptime: 0 days 0:58:32.414
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    * Bugcheck Analysis *
    BugCheck D1, {0, 2, 0, 89e15b26}
    *** ERROR: Module load completed but symbols could not be loaded for yk60x86.sys
    Probably caused by : yk60x86.sys ( yk60x86+eb26 )
    Followup: MachineOwner
    1: kd> !analyze -v;r;kv;lmtn;.logclose;q
    DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
    interrupt request level (IRQL) that is too high. This is usually
    caused by drivers using improper addresses.
    If kernel debugger is available get stack backtrace.
    Arguments:
    Arg1: 00000000, memory referenced
    Arg2: 00000002, IRQL
    Arg3: 00000000, value 0 = read operation, 1 = write operation
    Arg4: 89e15b26, address which referenced memory
    Debugging Details:
    AUTOBUG_OS_SKU: 3
    READ_ADDRESS: GetPointerFromAddress: unable to read from 81d315ac
    Unable to read MiSystemVaType memory at 81d117e0
    00000000
    CURRENT_IRQL: 2
    FAULTING_IP:
    yk60x86+eb26
    89e15b26 f70000000080 test dword ptr [eax],80000000h
    CUSTOMER_CRASH_COUNT: 1
    DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
    BUGCHECK_STR: 0xD1
    PROCESS_NAME: Idle
    TRAP_FRAME: 827ffbbc -- (.trap 0xffffffff827ffbbc)
    ErrCode = 00000000
    eax=00000000 ebx=854a2000 ecx=854b4154 edx=854b415c esi=854b2238 edi=854b2238
    eip=89e15b26 esp=827ffc30 ebp=827ffc40 iopl=0 nv up ei ng nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010286
    yk60x86+0xeb26:
    89e15b26 f70000000080 test dword ptr [eax],80000000h ds:0023:00000000=????????
    .trap
    Resetting default scope
    LAST_CONTROL_TRANSFER: from 89e15b26 to 81c8fd84
    STACK_TEXT:
    827ffbbc 89e15b26 badb0d00 854b415c 827ffc18 nt!KiTrap0E+0x2ac
    827ffc40 89e0edc4 854b2000 854b2238 00000000 yk60x86+0xeb26
    827ffc8c 89e11237 004b2000 00000000 855945f0 yk60x86+0x7dc4
    827ffca4 806e8086 854b2000 00000000 00000000 yk60x86+0xa237
    827ffcc8 80630252 85594604 89e18220 00000000 ndis!ndisMiniportDpc+0x81
    827ffce8 81ca93ae 85594604 855945f0 00000000 ndis!ndisInterruptDpc+0x8b
    827ffd50 81c913ee 00000000 0000000e 00000066 nt!KiRetireDpcList+0x147
    827ffd54 00000000 0000000e 00000066 00000000 nt!KiIdleLoop+0x46
    STACK_COMMAND: kb
    FOLLOWUP_IP:
    yk60x86+eb26
    SYMBOL_STACK_INDEX: 1
    SYMBOL_NAME: yk60x86+eb26
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: yk60x86
    IMAGE_NAME: yk60x86.sys
    DEBUG_FLR_IMAGE_TIMESTAMP: 4757ea2c
    FAILURE_BUCKET_ID: 0xD1_yk60x86+eb26
    eax=8241013c ebx=00000002 ecx=00001e55 edx=81d2943c esi=82410120 edi=00000000
    eip=81c8fd84 esp=827ffba4 ebp=827ffbbc iopl=0 nv up ei ng nz na pe nc
    cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
    nt!KiTrap0E+0x2ac:
    81c8fd84 833dc48dd28100 cmp dword ptr [nt!KiFreezeFlag (81d28dc4)],0 ds:0023:81d28dc4=????????
    827ffbbc 89e15b26 badb0d00 854b415c 827ffc18 nt!KiTrap0E+0x2ac (FPO: [0,0] TrapFrame @ 827ffbbc)
    827ffcc8 80630252 85594604 89e18220 00000000 ndis!ndisMiniportDpc+0x81 (FPO: [Non-Fpo])
    827ffce8 81ca93ae 85594604 855945f0 00000000 ndis!ndisInterruptDpc+0x8b (FPO: [Non-Fpo])
    827ffd54 00000000 0000000e 00000066 00000000 nt!KiIdleLoop+0x46 (FPO: [0,0,0])
    start end module name
    80200000 80207000 pciide pciide.sys Fri Jan 18 22:01:57 2008 (47916825)
    80207000 80209900 compbatt compbatt.sys Thu Aug 30 20:57:47 2007 (46D7678B)
    8020a000 80219000 volmgr volmgr.sys Tue Dec 12 22:29:12 2006 (457F7388)
    80219000 80221000 msisadrv msisadrv.sys Tue Dec 12 21:42:18 2006 (457F688A)
    80221000 8022a000 WMILIB WMILIB.SYS Thu Nov 02 04:54:53 2006 (4549B25D)
    8022a000 8026d000 acpi acpi.sys Thu Aug 30 20:57:46 2007 (46D7678A)
    8026d000 8027a000 WDFLDR WDFLDR.SYS Wed Dec 05 21:21:19 2007 (47575C9F)
    8027a000 802b5000 CLFS CLFS.SYS Wed Dec 05 20:55:42 2007 (4757569E)
    802b5000 802bd000 BOOTVID BOOTVID.dll Thu Nov 02 05:39:29 2006 (4549BCD1)
    802bd000 802c6000 PSHED PSHED.dll Thu Nov 02 05:42:51 2006 (4549BD9B)
    802c6000 802ce000 kdcom kdcom.dll Thu Nov 02 05:42:20 2006 (4549BD7C)
    80400000 80401800 NTIDrvr NTIDrvr.sys Tue Dec 21 15:33:14 2004 (41C8888A)
    80407000 80425000 ataport ataport.SYS Fri Jan 18 22:01:56 2008 (47916824)
    80425000 8042d000 atapi atapi.sys Fri Jan 18 22:01:56 2008 (47916824)
    8042d000 8043b000 PCIIDEX PCIIDEX.SYS Fri Jan 18 22:01:56 2008 (47916824)
    8043b000 80465000 pcmcia pcmcia.sys Thu Nov 02 04:35:13 2006 (4549ADC1)
    80465000 80475000 mountmgr mountmgr.sys Thu Nov 02 04:51:06 2006 (4549B17A)
    80475000 8047f000 BATTC BATTC.SYS Thu Aug 30 20:57:44 2007 (46D76788)
    8047f000 804a4000 pci pci.sys Tue Dec 12 21:42:27 2006 (457F6893)
    804a4000 8051f000 Wdf01000 Wdf01000.sys Wed Dec 05 21:21:28 2007 (47575CA8)
    8051f000 80600000 CI CI.dll Mon Feb 18 23:59:14 2008 (47BA6222)
    80604000 8062f000 msrpc msrpc.sys unavailable (00000000)
    8062f000 80733000 ndis ndis.sys Thu Nov 02 04:57:33 2006 (4549B2FD)
    80733000 8073c000 psdfilter psdfilter.sys Wed Apr 25 04:28:17 2007 (462F1121)
    8073c000 8074c000 fileinfo fileinfo.sys Thu Nov 02 04:36:47 2006 (4549AE1F)
    8074c000 8077d000 fltmgr fltmgr.sys Thu Nov 02 04:30:58 2006 (4549ACC2)
    8077d000 80785b80 o2sd o2sd.sys Mon Apr 02 04:11:06 2007 (4610BA9A)
    80786000 807ac000 SCSIPORT SCSIPORT.SYS Thu Nov 02 04:51:38 2006 (4549B19A)
    807ac000 807b5b00 o2media o2media.sys Mon Apr 02 22:04:27 2007 (4611B62B)
    807b6000 80800000 volmgrx volmgrx.sys Thu Nov 02 04:51:54 2006 (4549B1AA)
    81a05000 81a17000 psdvdisk psdvdisk.sys Tue Mar 13 07:04:44 2007 (45F6854C)
    81a17000 81a1f000 spldr spldr.sys Wed Oct 25 18:40:44 2006 (453FE7EC)
    81a1f000 81a55000 volsnap volsnap.sys Thu Oct 25 22:04:17 2007 (47214B21)
    81a55000 81abf000 ksecdd ksecdd.sys Thu Nov 02 04:43:45 2006 (4549AFC1)
    81abf000 81bc7000 Ntfs Ntfs.sys Sun Dec 16 04:31:37 2007 (4764F079)
    81bc7000 81c00000 NETIO NETIO.SYS Sun Jan 13 22:17:13 2008 (478AD439)
    81c00000 81fa1000 nt ntkrpamp.exe Tue Oct 23 21:45:00 2007 (471EA39C)
    81fa1000 81fd5000 hal halmacpi.dll Sat Dec 23 23:05:34 2006 (458DFC8E)
    82579000 82582000 crcdisk crcdisk.sys Thu Nov 02 04:52:27 2006 (4549B1CB)
    82582000 825a3000 CLASSPNP CLASSPNP.SYS Thu Nov 02 04:51:34 2006 (4549B196)
    825a3000 825b4000 disk disk.sys Thu Nov 02 04:51:40 2006 (4549B19C)
    825b4000 825d9000 ecache ecache.sys Thu Nov 02 04:52:42 2006 (4549B1DA)
    825d9000 825e8000 mup mup.sys Thu Nov 02 04:31:04 2006 (4549ACC8)
    825e8000 825f7000 partmgr partmgr.sys Thu Nov 02 04:51:47 2006 (4549B1A3)
    825f7000 82600000 PSDNServ PSDNServ.sys Tue Mar 13 07:04:32 2007 (45F68540)
    8261e000 8261f700 USBD USBD.SYS Thu Aug 30 21:23:36 2007 (46D76D98)
    82624000 82625380 swenum swenum.sys Tue Dec 12 22:28:16 2006 (457F7350)
    826ec000 826f4000 dump_atapi dump_atapi.sys Fri Jan 18 22:01:56 2008 (47916824)
    826f4000 826fc000 rdpencdd rdpencdd.sys Thu Nov 02 05:02:01 2006 (4549B409)
    8272c000 82734000 RDPCDD RDPCDD.sys Thu Nov 02 05:02:01 2006 (4549B409)
    82734000 8273b800 nscirda nscirda.sys Thu Nov 02 04:57:06 2006 (4549B2E2)
    827d0000 827df000 amdk8 amdk8.sys Thu Nov 02 04:30:18 2006 (4549AC9A)
    87a00000 87a0d000 crashdmp crashdmp.sys Thu Nov 02 04:51:36 2006 (4549B198)
    87a0d000 87a13380 HIDPARSE HIDPARSE.SYS Thu May 10 21:30:33 2007 (4643C739)
    87a54000 87a64000 NDProxy NDProxy.SYS Tue Jul 03 21:28:13 2007 (468AF7AD)
    87b24000 87b33200 ohci1394 ohci1394.sys Wed Feb 07 21:04:50 2007 (45CA8542)
    87b54000 87b60000 vga vga.sys Thu Nov 02 04:53:56 2006 (4549B224)
    87b88000 87b8b780 CmBatt CmBatt.sys Thu Aug 30 20:57:48 2007 (46D7678C)
    87be2000 87be7080 SYMREDRV SYMREDRV.SYS Mon Oct 23 20:29:54 2006 (453D5E82)
    89e07000 89e53000 yk60x86 yk60x86.sys Thu Dec 06 07:25:16 2007 (4757EA2C)
    89e53000 89e60000 watchdog watchdog.sys Thu Nov 02 04:37:44 2006 (4549AE58)
    89e60000 89e6b000 tunnel tunnel.sys Wed Jun 06 22:57:03 2007 (466773FF)
    89e75000 89e7f000 usbohci usbohci.sys Thu Aug 30 21:23:40 2007 (46D76D9C)
    89e7f000 89e89000 DKbFltr DKbFltr.sys Thu Oct 19 04:24:28 2006 (4537363C)
    89e89000 89e93000 mssmbios mssmbios.sys Tue Dec 12 21:42:24 2006 (457F6890)
    89e9d000 89ea7000 nsiproxy nsiproxy.sys Thu Nov 02 04:57:30 2006 (4549B2FA)
    89eb1000 89ebb000 ndisuio ndisuio.sys Thu Nov 02 04:57:22 2006 (4549B2F2)
    89ebb000 89ec5000 Dxapi Dxapi.sys Thu Nov 02 04:38:17 2006 (4549AE79)
    89ece000 89f0b000 USBPORT USBPORT.SYS Thu Aug 30 21:23:43 2007 (46D76D9F)
    89f79000 89f82000 tunmp tunmp.sys Wed Jun 06 22:56:53 2007 (466773F5)
    89f82000 89f8b000 wmiacpi wmiacpi.sys Thu Aug 30 20:57:47 2007 (46D7678B)
    89f9d000 89fa6000 irenum irenum.sys Thu Nov 02 04:57:04 2006 (4549B2E0)
    89fc1000 89fca000 Fs_Rec Fs_Rec.SYS unavailable (00000000)
    89fd3000 89fdc000 rasacd rasacd.sys Thu Nov 02 04:58:13 2006 (4549B325)
    8a203000 8a2a0000 dxgkrnl dxgkrnl.sys Mon Jul 02 21:01:10 2007 (46899FD6)
    8a2a0000 8a2af000 raspppoe raspppoe.sys Thu Nov 02 04:58:12 2006 (4549B324)
    8a2af000 8a2be000 termdd termdd.sys Tue Dec 12 22:53:43 2006 (457F7947)
    8a354000 8a363000 monitor monitor.sys Sun Dec 16 04:56:44 2007 (4764F65C)
    8a3cf000 8a3d6000 int15 int15.sys Mon Jul 02 22:03:24 2007 (4689AE6C)
    8a3d6000 8a3dcd00 sncduvc sncduvc.SYS Wed Dec 27 22:21:50 2006 (4593384E)
    8a3f2000 8a3f9000 Null Null.SYS unavailable (00000000)
    8a3f9000 8a400000 Beep Beep.SYS Thu Nov 02 04:51:03 2006 (4549B177)
    8a608000 8a616000 usbehci usbehci.sys Thu Aug 30 21:23:40 2007 (46D76D9C)
    8a616000 8a6d8000 athr athr.sys Wed May 07 20:55:20 2008 (48224F78)
    8a6d8000 8ae00000 atikmdag atikmdag.sys Sat Aug 11 23:09:56 2007 (46BE7A04)
    8ae07000 8ae12000 Msfs Msfs.SYS unavailable (00000000)
    8ae12000 8ae1f000 modem modem.sys Thu Nov 02 04:58:52 2006 (4549B34C)
    8ae6f000 8ae99000 ks ks.sys Fri Mar 07 21:14:06 2008 (47D1F66E)
    8ae99000 8aea6000 umbus umbus.sys Thu Nov 02 04:55:24 2006 (4549B27C)
    8aea6000 8aeb9000 raspptp raspptp.sys Mon Jan 08 21:17:01 2007 (45A2FB1D)
    8aeb9000 8aedc000 ndiswan ndiswan.sys Thu Nov 02 04:58:13 2006 (4549B325)
    8aedc000 8aee7000 ndistapi ndistapi.sys Tue Jul 03 21:28:09 2007 (468AF7A9)
    8aee7000 8aefe000 rasl2tp rasl2tp.sys Mon Jan 08 21:17:02 2007 (45A2FB1E)
    8aefe000 8af09000 TDI TDI.SYS Thu Nov 02 04:58:46 2006 (4549B346)
    8af09000 8af49000 storport storport.sys Thu Nov 02 04:51:45 2006 (4549B1A1)
    8af49000 8af74000 msiscsi msiscsi.sys Thu Nov 02 04:52:40 2006 (4549B1D8)
    8af74000 8af81080 1394BUS 1394BUS.SYS Wed Feb 07 21:04:45 2007 (45CA853D)
    8af82000 8af8d000 mouclass mouclass.sys Wed Dec 05 21:18:22 2007 (47575BEE)
    8af8d000 8afb7380 SynTP SynTP.sys Mon Oct 23 13:52:26 2006 (453D015A)
    8afb8000 8afc3000 kbdclass kbdclass.sys Wed Dec 05 21:18:23 2007 (47575BEF)
    8afc3000 8afd6000 i8042prt i8042prt.sys Wed Dec 05 21:18:28 2007 (47575BF4)
    8afd6000 8afe8000 HDAudBus HDAudBus.sys Sat Mar 24 14:54:34 2007 (460573EA)
    8afe8000 8b000000 cdrom cdrom.sys Thu Nov 02 04:51:44 2006 (4549B1A0)
    8b000000 8b00b000 dump_dumpata dump_dumpata.sys Thu Nov 02 04:51:34 2006 (4549B196)
    8b00b000 8b019000 Npfs Npfs.SYS Thu Nov 02 04:30:57 2006 (4549ACC1)
    8b019000 8b03a000 VIDEOPRT VIDEOPRT.SYS Thu Nov 02 04:54:07 2006 (4549B22F)
    8b03a000 8b13d000 HSX_DPV HSX_DPV.sys Wed Nov 08 18:55:07 2006 (45526E5B)
    8b13d000 8b17a000 HSXHWAZL HSXHWAZL.sys Wed Nov 08 18:53:56 2006 (45526E14)
    8b17a000 8b19f000 drmk drmk.sys Thu Nov 02 05:20:49 2006 (4549B871)
    8b19f000 8b1cc000 portcls portcls.sys Thu Nov 02 04:55:02 2006 (4549B266)
    8b1cc000 8b200000 usbhub usbhub.sys Thu Aug 30 21:24:00 2007 (46D76DB0)
    8b225000 8b3ffe40 RTKVHDA RTKVHDA.sys Wed Aug 22 06:44:12 2007 (46CC137C)
    8b400000 8b40ce80 STREAM STREAM.SYS Thu Nov 02 04:55:00 2006 (4549B264)
    8b44d000 8b462000 tdx tdx.sys Thu Nov 02 04:57:34 2006 (4549B2FE)
    8b462000 8b47b000 fwpkclnt fwpkclnt.sys Thu Nov 02 04:57:26 2006 (4549B2F6)
    8b47b000 8b54c000 tcpip tcpip.sys Sun Jan 13 22:17:51 2008 (478AD45F)
    8b54c000 8b600000 HSX_CNXT HSX_CNXT.sys Wed Nov 08 18:53:45 2006 (45526E09)
    8b629000 8b640000 dfsc dfsc.sys Thu Nov 02 04:31:04 2006 (4549ACC8)
    8b6a2000 8b6dd000 rdbss rdbss.sys Thu Nov 02 04:31:24 2006 (4549ACDC)
    8b6ee000 8b710000 SYMEVENT SYMEVENT.SYS Wed Oct 18 00:13:40 2006 (4535A9F4)
    8b710000 8b73bf00 SYMTDI SYMTDI.SYS Mon Oct 23 20:26:29 2006 (453D5DB5)
    8b73c000 8b74f000 wanarp wanarp.sys Tue Jul 03 21:28:16 2007 (468AF7B0)
    8b74f000 8b75d000 netbios netbios.sys Thu Oct 19 19:38:12 2006 (45380C64)
    8b75d000 8b773000 pacer pacer.sys Tue Jul 03 21:27:33 2007 (468AF785)
    8b773000 8b7a5000 netbt netbt.sys Thu Nov 02 04:57:18 2006 (4549B2EE)
    8b7a5000 8b7ec000 afd afd.sys Thu Nov 02 04:58:41 2006 (4549B341)
    8b7ec000 8b800000 smb smb.sys Thu Nov 02 04:57:10 2006 (4549B2E6)
    8bc19000 8bdbf280 snp2uvc snp2uvc.sys Mon Jun 11 22:38:23 2007 (466E071F)
    8c371000 8c37c000 tcpipreg tcpipreg.sys Thu Nov 02 04:57:46 2006 (4549B30A)
    8c39d000 8c3d8000 udfs udfs.sys Thu Nov 02 04:30:57 2006 (4549ACC1)
    8c3d8000 8c400000 fastfat fastfat.SYS Thu Nov 02 04:30:49 2006 (4549ACB9)
    93a00000 93bff000 win32k win32k.sys unavailable (00000000)
    94210000 94220000 lltdio lltdio.sys Thu Nov 02 04:56:48 2006 (4549B2D0)
    942f8000 94300000 xaudio xaudio.sys Fri Aug 04 20:39:09 2006 (44D3E8AD)
    94508000 94512000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
    94600000 94609000 TSDDD TSDDD.dll unavailable (00000000)
    94610000 9461e000 cdd cdd.dll unavailable (00000000)
    95400000 95413000 rspndr rspndr.sys Thu Nov 02 04:56:48 2006 (4549B2D0)
    95513000 9552e000 luafv luafv.sys Thu Nov 02 04:33:07 2006 (4549AD43)
    970b3000 970de000 nwifi nwifi.sys Fri Jan 18 22:06:33 2008 (47916939)
    970de000 970fc000 irda irda.sys Thu Nov 02 04:57:09 2006 (4549B2E5)
    9748c000 974f2000 HTTP HTTP.sys Thu Nov 02 04:57:06 2006 (4549B2E2)
    97572000 97600000 spsys spsys.sys Wed Oct 25 18:43:28 2006 (453FE890)
    9867f000 986cb000 srv srv.sys Thu Nov 02 04:31:55 2006 (4549ACFB)
    986cb000 986ef000 srv2 srv2.sys Thu Oct 25 21:40:47 2007 (4721459F)
    986ef000 98701000 mrxsmb20 mrxsmb20.sys Thu Oct 25 21:40:16 2007 (47214580)
    98701000 9873a000 mrxsmb10 mrxsmb10.sys Thu Nov 02 04:31:25 2006 (4549ACDD)
    9873a000 98758000 mrxsmb mrxsmb.sys Thu Oct 25 21:40:17 2007 (47214581)
    98758000 98778000 mrxdav mrxdav.sys Fri Jan 11 20:45:54 2008 (47881BD2)
    98778000 9878c000 mpsdrv mpsdrv.sys Wed Jun 06 22:55:55 2007 (466773BB)
    9878c000 987a5000 bowser bowser.sys Thu Nov 02 04:31:11 2006 (4549ACCF)
    987e5000 98800000 srvnet srvnet.sys Thu Oct 25 21:40:43 2007 (4721459B)
    99175000 99178180 mdmxsdk mdmxsdk.sys Mon Jun 19 17:26:59 2006 (449716A3)
    99662000 99740000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
    Unloaded modules:
    8b640000 8b6a2000 eeCtrl.sys
    Checksum: 00000000
    8b6dd000 8b6ee000 SRTSPX.SYS
    Checksum: 00000000
    9bef7000 9bf40000 SRTSP.SYS
    Checksum: 00000000
    99003000 99015000 NAVENG.SYS
    Checksum: 00000000
    9be2d000 9bef7000 NAVEX15.SYS
    Checksum: 00000000
    94370000 94378000 drmkaud.sys
    Checksum: 00000000
    98627000 9863f000 parport.sys
    Checksum: 00000000
    87a00000 87a0d000 crashdmp.sys
    Checksum: 00000000
    89f65000 89f70000 dump_ataport
    Checksum: 00000000
    8275c000 82764000 dump_atapi.s
    Checksum: 00000000
    89fca000 89fd3000 kbdhid.sys
    Checksum: 00000000
    Closing open log file c:\debuglog.txt
  2. 2008/07/11
    Hi,
    Welcome to WindowsBBS!
    If it always crashes with yk60x86.sys you should try installing the latest driver. Try both Acer & Marvell. If that doesn't help, and the cash is always with the Marvel driver, you can safely pinpoint that (hardware) as culprit.
    Paintballparrot
    But if it doesn't work is there a way to stop Vista from enabling the device on start up? and could I just uninstall the device in Device Manager without causing other problems?
  5. 2008/07/11
    If you never want to use the wired LAN, the best option would be to disable it from your computers BIOS. If you just remove it from Device Manager, Windows would just 'rediscover' the device when you reboot.
