Quick launch - unchecks on system startup
Discussion in 'Windows XP' started by dchalliwell, 2005/11/21.
  1. 2005/11/21
    dchalliwell
    dchalliwell Inactive Thread Starter
    The show Quick Launch" setting unchecks itself each time on system startup. When I select it and save it reappears, but then next time I reboot, no quick launch show and start menu taskbar "show quick launch" is again unchecked. Any help or suggestions would be appreciated thanks
    duncan
  2. 2005/11/21
    charlesvar
    charlesvar Inactive Alumni
    Hello duncan,
    try this: before selecting the QL, unlock the Tool Bar by clicking on that line. And don't lock the Tool Bar, no need.
    Regards - Charles
    Miz
    Miz Inactive Alumni
    If charlesvar's suggestion doesn't work, try the fix on Kelly's Korner, line 30.
    Click on "Windows XP Doesn't Save User Settings" to download a small .reg file and run it according to the directions at the top of the Kelly's Korner page.
    Miz,
    dchalliwell
    Quick launch
    Thanks Charles - unfortunately didnt work
    Miz - will try your suggestion
    Thanks to both of you for prompt replies
    I had really frustrating time trying to find anything relating to this from micrsoft - surprise surprise !!
    Duncan
