Question about Web Hosting
Discussion in 'General Discussions' started by VaCcAr0, 2010/09/26.
  1. 2010/09/26
    VaCcAr0
    VaCcAr0 Well-Known Member Thread Starter
    I'm brand new to creating a website and I'm in the process of starting my first. I've just been looking around and making sure I know what I'm doing before I jump into anything.
    If anyone can help me me out with this I would appreciate it:
    Do you have to get web hosting from the same place you purchased your domain name? Because I was wondering if I'm able to buy my domain name at godaddy and get web hosting from webair. I just wanted to know if that would be possible (or recommended). The reason I wanted to do this is because the domain name is cheapest at godaddy but I keep hearing how much better webair is as a hosting site.
  2. 2010/09/26
    The short answer is no.
    You could host with anybody you like but having only one provider for both domain name & hosting provides you a single point contact & less hassles.
    VaCcAr0
    So it's better to either get the domain AND hosting from either godaddy or webair but you don't recommend to mix/match between the two?
  5. 2010/09/27
    wildfire
    wildfire Getting Old
    I agree with rsinfo on this,
    Although technically there should be nothing to stop you mixing and matching, if you encounter any problems you could be caught in a catch 22 situation...
    The host blaming the provider and vice versa, using only one company kills that argument straight away.
    FWIW if you want to play before you buy and your site isn't too busy (eg keep it amongst a select group of friends/colleagues whilst testing) you could use a free service such as dyndns.com and host the site yourself.
    I done exactly the above for a couple of years for our local computer group with very few problems. Obviously you'd need to keep your server running 24/7 but it's perhaps worth considering.
  6. 2010/09/27
    VaCcAr0
    do you recommend any particular webhosts?
  7. 2010/09/27
    There's no such possibility IMHO. If your domain name is in the DNS & pointing to the correct name server (presumably at your host), all is clear!
  8. 2010/09/27
    wildfire
    Agreed, but some of these companies will try anything ;)
    One point of contact is better IMO unless you're making a significant saving.
    EDIT: VaCcArO (I hate it when users mix case like that :D) anyway, just to be clear my comment above has nothing to do with the companies you have named. I have never heard of them and cannot say whether or not they'd engage is such dubious tactics)
    As far as recommendations go, it all depends on your needs (bandwidth/reimbursement for downtime etc) and TBH I'm not experienced enough in the field to offer any suggestions.
  9. 2010/09/27
    Yup, the point about savings is true...
  10. 2010/09/27
    As was stated, there's no reason you can't register a domain name somewhere and host the site elsewhere. However, you will have to manually change the DNS settings for the domain and the MX records for email at the registrar. The registrar will not do this for you. If you are uncomfortable editing DNS records and MX records, then use one place for registration and hosting.
    IMHO, I would not use GoDaddy. I've been managing Web sites for clients and myself since 1999. GoDaddy has strict transfer rules and once they double charged my credit card auto-renewing a domain and hosting after I'd canceled the service. It took a couple weeks for them to return my money. They also lock your domains even when you set them to unlocked.
    Many places offer free domain names with hosting. For personal sites and small business sites this is a good host: www.ezhoster.com
  11. 2010/09/27
    VaCcAr0
    ahh, I read Tony's post a little too late. I just bought my domain name from Godaddy because I wanted to make sure I had it before anyone else (not that I think it would've been gone anytime soon, but it's a very good name nonetheless). I also had discount codes to use for godaddy so I have the name for 1 year for $7. All in all I'm glad I did because now the domain name is mine all mine muahahaha.
    Right now I'm trying to learn all I can about web hosting and be well-informed before I jump into anything else.
  12. 2010/09/28
    VaCcAr0
    Has anyone else ever heard of Host Gator? I heard they were one of the best for web hosting. I may use them. Also, do you recommend that I get a web host package now or should I wait until after I have created my webpages first?
    Thanks in advance for any advice you can offer.
  13. 2010/10/26
    HectorH
    HectorH Inactive
    I have to disagree. It is not that hard to use a separate hosting company especially with godaddy. Plus, godaddy hosting is not that good. They are a great registrar though. I like hostgator. A Small Orange is very good too. All you have to do is sign up with hostgator,, etc. They will give you instructions on changing your DNS. Very easy.
  14. 2010/10/28
    For a simple Web site you can host the site at the free Web space provided by your ISP. Go to your ISP site and activate your free Web space. Then go to godaddy and forward the domain to the address provided by your ISP.
