program problem
Discussion in 'Legacy Windows' started by achild, 2003/06/12.
  1. 2003/06/12
    achild
    achild Inactive Thread Starter
    how do you go about fixing file after you accendient delete them now all the say the drive or network connection that the short cut ink refers to is unavailable?
  2. 2003/06/12
    markp62
    markp62 Geek Member Alumni
    Did you look in the Recycle Bin?
    Reinstall deleted programs?
    Clarify what you mean?
    Otherwise, delete the bad shortcuts, they are pointing to nothing.
    achild
    yes i went to the recyled bin i click empty it but didn,t work some of my file are missing when you go the accessories click what you want it show up a blank picture beside the word.
  5. 2003/06/13
    achild
    how do you go about reinstall deleted program files from the recycled bin?
  6. 2003/06/14
    achild
    thanks alot for helping.i did what you say to do about reinstall it. that did the job.big help:) :cool:
