Problems with WinFax Pro
Discussion in 'Other PC Software' started by alc, 2005/06/08.
  1. 2005/06/08
    alc
    alc Inactive Thread Starter
    I installed version 10.01 of WinFax Pro last night and I can't get it to work. So, I removed it using the "Add and Remove Programs" in the Control Panel. Now, I am getting the following error when I open MS Word:
    Microsoft Visual Basic
    Compile error in hidden module: WinFaxPrintandMerge
    The removal did not delete the files and/or folders for either WinFaxPro or Symantac Live Update. Should I remove both of those folders with the files in them or is this something else. I have no clue. Any help would be appreciated.
    alc,
  2. 2005/06/08
    Not familiar with WinFax, but under these circumstances - a partly failed uninstall I would reload WinFax, reboot and then uninstall again and reboot.
    If that does not solve the Word problem try a repair - Help > Detect & Repair.
    Unless some one else has any other ideas ....
    alc
    I tried the Word detect and repair, but it didn't help. I will try your suggestion to reload and uninstall again. Thanks.
    alc,
    alc
    Before doing another install and uninstall, I did a little research on the Symantec site and found an article about problems with Word macros following the installation of WinFax Pro 10.02. My version was 10.01, but I tried the solution and it fixed my problem.
    I have come to the conclusion that Symantec products cause some of the most hard to fix problems ever. I have had major problems with both NAV and Norton Ghost messing up other programs and those problems were not easy to fix. In fact, I never could get a problem with Ghost fixed so I quit using it and started using Acronis True Image. It is a much easier program to work with.
    alc,
    Glad to hear that you found a solution - thanks for sharing it!
    :D :D :D
