problems with the webpage might prevent it from being displayed properly or
Discussion in 'Internet Explorer & Microsoft Edge' started by Mithun, 2008/10/17.
  1. 2008/10/17
    Mithun
    Mithun Inactive Thread Starter
    hi
    i am facing one problem in particular website https://strade.sharekhan.com. I am able to open the webpage but when i am trying to Login it is giving me error message " problems with the webpage might prevent it from being displayed properly or functioning Properly. I n the future you can display the message by double clicking the warning icon displayed in the status bar
    LINE : 207
    CHAR: 1
    ERROR : OBJECT DOESN'T SUPPORT THIS PROPERLY OR METHOD
    CODE : 0
    URL : HTTPS://STRADE.SHAREKHAN.COM/MMWEB/APPLET
    ACTION TAKEN BY ME
    1 INSTALLED JRE LATEST VERSION
    2 INSTALLED JVM
    3 REINSTALLED INTERNET EXPLORER FROM CONTROL PANEL->ADD OR REMOVE PROGRAMS->ADD/REMOVE COMPONENTS->INTERNET EXPLORER
    Windows xp is installed on my system with IE7
  2. 2008/10/17
    Mithun
    hi
    Same website is opening on another System and also in same system when i use Mozilla Firefox
  5. 2008/10/17
    Firefox is a independent browser so that does rather point the finger at IE - try the suggestions outlined in the URL I posted.
  6. 2008/10/17
    Mithun
    hi
    sorry i forgot to tell that when i click on ok it is not opening the page
  7. 2008/10/20
    msquare13
    msquare13 Inactive
    Hi Mithun,
    I'm using the same configuration as yours & am able to access the url.
    Request you to send across a screen shot of the error to myaccount AT sharekhan.com & merwyn AT sharekhan.com so that they can check on the same.
    In case you are located in India, penning down your contact details would help so that they can touch base with you.
    Regards
