Problems with the extension by saving files
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by ChicoBoy, 2006/01/23.
  1. 2006/01/23
    ChicoBoy
    ChicoBoy Inactive Thread Starter
    Hey all!!
    I want to save a csv-file and save them by using the following php-code:
     header( "Content-disposition: attachment; filename=My_File.csv);
       header( "Content-type: application/octest-stream ");
       header( "Pragma: no-cache ");
       header( "Expires: 0 ");
    for($i=0;$i<10;$i++){
       echo  "number,\" $i \ ", \ "blabla \ "\n ";
    With Firefox und MIE it works perfectly and you can save the file 'My_File.csv'.
    But in Netscape7.1 the download-menu showed 'My_Datei.csv.php' instead of 'My_Datei.csv' .
    So i allways have to remove this '.php' at the end of the string in the save-dialog.
    Why does Netscape allways add this php-extension??
    I allready searched in google about this problem, i only found several people who got the same problem but no solutions yet.
    Thanks in advance for any help!
  2. 2006/01/23
    Westside
    Westside Inactive Alumni
    My, simple minded, solution is to do away with NS7.1. I recall that some earlier Netscape used to add stuff to the download. It is my recollection that 7.2 had no longer the problem, should you wish to stick to Netscape.
    I simulated what you described, and if selected All Files, it saved with desired name, using 7.2.
    Ramona
    Ramona Geek Member Alumni
    Welcome to the Forum, ChicoBoy!
    ChicoBoy,
    The extra extension on the file is one of the many bugs in Netscape 7.1.
  5. 2006/01/24
    ChicoBoy
    Thank oyu both for the fast reply...
    I allready recommend the customers who are using my 'tool' to install firefox, IE, or just to upgrade Netscpae to e newer version...
    Thanks a lot..
