Problems with Magicjack
Discussion in 'PC Hardware' started by BAT, 2011/12/22.
  1. 2011/12/22
    BAT
    BAT Inactive Thread Starter
    I have a new PC running Windows 7. It does not like Magicjack and I am a loss as to why. I have never been able to access magicjack.com from this machine using either IE or Firefox, it just never finishes loading (no error messages). I can go to my laptop (wireless) or my old XP machine and they do not have any problem. They are all on the same router. I moved my magicjack usb device to the new machine, it worked for a few days but was not able to download contacts or call history, then it just quit working. I have disconnected it and uninstalled the program from the pc but still cannot connect to the website. Anyone have any ideas?
    BAT,
  2. 2011/12/22
    cspgsl Lifetime Subscription
    cspgsl Geek Member
    I noticed that if I plugged the MJ into the front USB ports on my machine it didn't work. I only found success when it was plugged into the back. The ports work fine with everything else though.
    BAT likes this.
    Athlonite
    Athlonite Inactive
    Have you tried contacting magicjack at all also your ISP may well be blocking the site I'd ring them and ask
    open a cmd window and type the folowing
    tracert www.magicjack.com
    and paste the result here
    BAT likes this.
  5. 2011/12/23
    BAT
    to CSGPSI, thanks for the tip, I'll play & see if it makes a difference on this machine.
    to Athlonite, here is the trace. Strange thing, the first entry is DELLBRUCE which is my old computer who is no longer with us. The current machine is Bruce-HP and the router says the it is on 19..168.2.8.
    C:\Users\Bruce>tracert www.magicjack.com
    Tracing route to www.magicjack.com [216.234.76.40]
    over a maximum of 30 hops:
    1 <1 ms <1 ms <1 ms DELLBRUCE [192.168.2.1]
    2 10 ms 8 ms 8 ms 10.147.64.1
    3 12 ms 9 ms 8 ms 68.2.8.17
    4 12 ms 9 ms 10 ms 70.169.75.84
    5 11 ms 9 ms 9 ms chnddsrj01-ae2.0.rd.ph.cox.net [70.169.76.229]
    6 75 ms 75 ms 77 ms nyrkbprj02-ae2.0.rd.ny.cox.net [68.1.2.241]
    7 100 ms 84 ms 99 ms 207.88.14.185.ptr.us.xo.net [207.88.14.185]
    8 101 ms 106 ms 106 ms te-3-0-0.rar3.atlanta-ga.us.xo.net [207.88.12.9]
    9 100 ms 99 ms 99 ms ae0d0.mcr1.nashville-tn.us.xo.net [216.156.0.74]
    10 103 ms 102 ms 103 ms 216.55.51.18
    11 99 ms 101 ms 101 ms www.magicjack.com [216.234.76.40]
    Trace complete.
    BAT,
    Athlonite
    Athlonite Inactive
    OK so it doesn't seem to be blocked by your ISP then maybe it's just a failing device I'd give magicjack a call if it's still under warranty and have them replace it
    can you also check your firewall aswell it maybe that it's blocking the port/ports required for the magicjack (ports 49152-65535 UDP)
  7. 2011/12/23
    I hear that MagicJack Plus is really nice. You plug it into your router and the pc doesn't have to be turned on.
  8. 2011/12/23
    BAT
    magic jack is unplugged, application has been removed. turned off windows firewall. started firefox, enter www.magicjack.com, never loads. if I ping www.magicjack.com, the reply is normal. checked internet settings, they are identical to the settings on my laptop which is running vista. also, I was on with magicjack for a couple of hours yesterday, I eventually got transfered to one of their top 10% reps. After another hour or so, I lost the connection and was not able to get back on.
    BAT,
    #7
  9. 2011/12/24
    Not sure what to tell you, but it looks like you aren't getting to the correct address. I suggest trying another DNS server, or talk to your ISP.
    If I run a tracert from our server in the US, this is where the trace ends up:
    If I run it from my PC at home (Malta):
    As you can see, they both end in web08.talk4free.com
  10. 2011/12/24
    SpywareDr
    Same results here from two locations down in South Florida, USA:
    (*) CIDR: 216.55.0.0/18 XO Communications
  11. 2012/01/11
    BAT
    time to close the thread
    After spending many hours with customer support from HP, Magicjack, and cox I have more or less given up. As far as I have been able to determine, the only restriction I have with this pc is that it refuses to display any of the magicjack web sites. This is true using IE, firefox, and chrome, with and without a firewall, and with every possible internet access setting. I want to thank everyone for their suggestions.
    BAT,
    #10
  12. 2012/01/11
    ephemarial
    ephemarial Well-Known Member
    Just a thought before you go.
    Wonder if network connection is using the HOSTS file and it was altered?
    I’d try 2 things:
    Reset Hosts file to default.
    Microsoft has a handy dandy fixit tool here
    And don’t use the lmhosts file.
    Network connections – Internet Protocol (TC/IP), properties –Advanced button – WINS tab – and make sure Enable LMHOSTS lookup – is unchecked
  13. 2012/01/11
    BAT
    I did the first part, had no effect.
    Cannot follow the second part - Network connections? - have "network sharing center" or "internet options ", neither provides the described path. What am I missing?
    BAT,
    #12
  14. 2012/01/11
    ephemarial
  15. 2012/03/20
    BAT
    Nothing worked. I still cannot access the magicjack website from this computer. I purchased a magicjack plus and installed it on my router using my laptop, it works great. Strangely, I still have not encountered the problem on any other site. It is now time to give up and close this thread.
    BAT,
    #14
