Problems typing an email.
Discussion in 'General Internet' started by Nanshark, 2008/03/17.
  1. 2008/03/17
    Nanshark
    Nanshark Inactive Thread Starter
    Lately, when I am typing an email it will occasionally start dropping the last word typed into the next line and then when I hit the space bar that word will move up into the apropriate place, until I get to the last word, it stays in the next line even if there is plenty of room above. It doesn't do this on every email and sometimes it starts doing it half way through an email. I appreciate any help you can give me.
    Nanshark
  2. 2008/03/17
    Which email application are you using?
    Nanshark
    Typing problems
    I am on AOL and type my emails from there. I have interntet explorer but don't use it much except to clean out temp files and cookies. Does that answer your question?
    When I got the first reply I looked for a reply button to answer you but couldn't find it. Maybe I overlooked it somehow.
  5. 2008/03/17
    Are you 100% certain you aren't accidently hitting the Enter key..which would cause the next word to drop to the next line?
    Do these issues happen on New mails you're creating or do they happen when you reply to a mail?
  6. 2008/03/17
    Nanshark
    Typing problems
    I think it is happening at both times. It definitely happens when typing a new email, but I think it also happens when I reply. It is not from hitting the enter key because when it starts to do this it continues it throughout the rest of the email. Then when I start another it works ok, at least for a while. It doesn't do it all the time and not on every email. I first thought it had something to do with the insert key because I had a problem with that until it was explained to me, but clicking on that doesn't seem to correct the problem.
    It is not something I cannot live with, just frustrating. I appreciate you trying to help me.
