[Problems running] defrag
Discussion in 'Legacy Windows' started by Mandy, 2005/02/15.
  1. 2005/02/15
    Mandy
    Mandy Inactive Thread Starter
    on my dell lat 366xt laptop I can not run defrag........it has gone as far as 19 min but thats it........programs are shut down and no one has touched the computer while running.......continues to go back to 0% any ideas? thanks
  2. 2005/02/17
    Miz
    Miz Inactive Alumni
    Have you tried running it in Safe Mode? To enter Safe Mode, repeatedly press and release the F8 key while the computer is booting. That should get you to the boot menu where you can choose Safe Mode.
    Miz,
    Please follow Posting Rules (#3 - Meaningful Subject) when posting.
    I have adjusted your subject.
  5. 2005/02/18
    Mron
    Mron Inactive
    If a process writes to the drive while it's being defragged, defrag will start all over.
    It could be an application logging, windows event log, an autoupdater, or just about anything writing to the drive.
    Check your event logs for new or recent events, they may help find problems you didn't know your PC was suffering from.
    Defrag is best done in safe mode, or using a 3rd party command-line pre- Windows logon type program.
    Mron,
