problems installing to correct drive
Discussion in 'Windows XP' started by mrtucson, 2003/06/08.
  1. 2003/06/08
    mrtucson
    mrtucson Inactive Thread Starter
    on most programs that i install it goes directly to my drive e instead of drive c:\
    i use to have win xp pro on drive e:\ but had so many errors i got a new HD and installed win xp home on drive c:\ and kept e as my back up drive.
    is there a place on xp that i can change it to default to drive c as where my downloads and files get installed to?
    just driving me nuts and drive e is almost completly full.
    thanks
    Mrtucson
    :confused: :cool:
  2. 2003/06/08
    charlesvar
    charlesvar Inactive Alumni
    Hello mrtucson,
    If you've got a folder on that drive lableled "downloads ", get rid of it. "Downloads" is a default folder created by the OS on install.
    You should have a "downloads" folder on the C drive only.
    Whenever I want to install or download anything, I'm asked where to. If your not being asked, go into the Browser's options, the advanced tab, and UN-tick the box for "install on demand ", the demander is the web site.
    Regards - Charles
