Problems Formatting
Discussion in 'Windows XP' started by DeeGee88, 2006/10/12.
  1. 2006/10/12
    DeeGee88
    DeeGee88 Inactive Thread Starter
    Hi Guys,
    I recently decided to take a quantum leap....LOL and say 'farewell' to 98se, move into the future??? and install XP Pro - I didn't anticipate any dramas.
    My PC has 2 HDDs - 40gb (part 10/30) and 80gb (20/60) so I moved all wanted data to the 80gb drive and loaded the XP Pro disk - so far so good.
    My intention was to load XP on to the 10gb partition (Fat32) and keep the other drives as they were.
    My problems started when the XP disk wanted to keep formatting ALL partitons when I really only wanted the first drive done.
    I was of the opinion that I could leave the 98se Fat32 file system on the second drive and access it as normal. Would this work if I disconnected the 80g drive until the OS was loaded? I have a massive amount of data on the second drive and backups would be a major PIA.
    I know you guys can help,
    TIA
    Den
  2. 2006/10/13
    bluzkat
    bluzkat Inactive
    It would be a good idea to remove the 80gb drive (just to be safe) and it would limit Windows choices for installation. If you don't need to save anything on the 40gb disk... boot the WinXP cd, follow the prompts for an installation, then 'delete' the partitions on that disk and then have XP create and format a new one or two. Here's some extra information for a WinXP clean install that may be of use.
    B :cool:
    Christer
    Christer Geek Member Staff
    If you want "some order" among the drive letters, disconnect all peripheral devices, such as card readers, printers (that have or haven't got integrated card readers), scanners and everything else.
    When XP has been installed on C:, the other partition on that disk will become D:, the opticals E: and F: (if you have two of them).
    In Disk Management, change the drive letters for the opticals to e.g. X: and Y: to get them "out of the way" for the second HDD. Shut down and connect the second HDD. Restart and it will get the drive letters E: and F:.
    Connect any card reader that you may have and it will get drive letters in sequence. If a printer has integrated card readers, I believe that they too get drive letters in sequence.
    Disconnecting all peripheral hardware makes it easier for XP to install and also more difficult to mess things up.
    Christer
  5. 2006/10/13
    sparrow
    sparrow Inactive
    Read the information on the blue installation pages more carefully. I'm reasonably certain that you misunderstood. The installation program offers to do whatever you wish, but you needn't do any formatting at all if you don't need to.
    There's also no reason to remove the 80 Gig HDD while installing XP.
    I install XP on FAT32 partitions all the time, even my XP Pro X64 running on an athlon 64. That's because I do personal rather than business computers.
  6. 2006/10/13
    DeeGee88
    Thanks guys,
    I feel a little more confident now and will try your ideas (I'm always a bit iffy with something I'm unfamiliar with)
    I'll let you know how it goes,
    Den
