Windows Vista Problems Downloading
Discussion in 'Legacy Windows' started by sandilew, 2008/12/14.
  1. 2008/12/14
    sandilew Lifetime Subscription
    sandilew Well-Known Member Thread Starter
    I use the Webshots Desktop for my wallpaper and screensaver, and things have worked smoothly for a long time with no hangups.
    Now I'm having problems, and I'm lost as to why.
    #1 I'm told I may not have the proper permissions (I'm the ONLY user on the computer)
    #2. This is a recent error message I recieved when trying to download a photousing Firefox.
    C:\Users\SANDIE~1\AppData\Local\Temp\39dde6a91927b159603e5e4c78323f8d-1.wbz could not be
    opened, because anunknown error occured.
    Try saving to disk first and then opening the file
    Using IE7 I get this message,
    Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item
    Last week I had similar problems, and then discovered that my Webshots Desktop needed to be updated. After updating the downloads worked again with no problems. But suddenly today I am getting the same messages I received last week before updating.
    I cleared the temporary Internet files. I rand a Disk Cleanup
    I opened IE7 with "Run as administrator ", which is totally frustrating me, and it made no difference whatsoever.
    Any suggestions?
  2. 2008/12/17
    You can navigate to that folder,
    the Temp folder for your user profile, and delete everything inside it. See if that makes any difference.
    I solved the problem by removing the Webshots Desktop program, then I downloaded the latest version and installed it. Everything is working fine now.
    I did try emptying the temp folder, and I did a disk cleanup, it didn't work. There must have been a glitch in the updated version after I installed it over the old program. But do a clean install worked.
    Thanks for your suggestion.
