problems caused by Microsoft IE 06
Discussion in 'Internet Explorer & Microsoft Edge' started by rodney06, 2007/04/26.
  1. 2007/04/26
    rodney06
    rodney06 Inactive Thread Starter
    Application Hang is what I get when I send the error report.
    All security updates are installed except one, framework, failed I can not reinstall it.
  2. 2007/04/26
    Which application is hanging - OE 6?
    rodney06
    oe6
    Yes, OE 6, sorry it took me so long to reply
  5. 2007/04/27
    Before I propose a course of action are you running XP with SP1 or SP2?
    If you don't know Right click My Computer icon > Properties and look under System on the General tab.
  6. 2007/04/27
    rodney06
    Windows XP Professional
    Xp2
  7. 2007/04/27
    rodney06
    Xp2
    Sorry, I don't understand this forum yet
  8. 2007/04/28
    A number of possible solutions ....
    Disable all add-ons you have installed in Internet Explorer - see here ...
    http://www.microsoft.com/windowsxp/using/web/sp2_addonmanager.mspx
    If the problem is resolved re-activate each add-on in turn until you find the one causing the problem.
    Do you have the Yahoo Toolbar installed? If so uninstall it and see if the problem is resolved.
    Repairing IE in XP SP2 is nigh on impossible, especially if SP2 was installed along with operating system rather than being installed later ....
    http://support.microsoft.com/default.aspx?scid=kb;en-us;318378
    One way in which a re-install can be forced .....
    In Windows Explorer go to Tools > Folder Options > View and check 'Show hidden files & folders'.
    Then navigate to ....
    C:\WINDOWS\inf\ie.inf
    Right click on the ie.inf file and select install.
