Problems after using anti trojan software
Discussion in 'Windows XP' started by glynmaggs, 2005/12/31.
  1. 2005/12/31
    glynmaggs
    glynmaggs Inactive Thread Starter
    I used Ewido free version a few days ago on my Toshiba laptop (Win XP home). It found many infections which I deleted. I'm now having problems when I insert items onto the USB. It detects the item (sound bing-bong) but does not bring up the options window "windows can perform the same action each time you......). The device on the usb can be accessed in explorer so it must be loaded. In particular I have a built in memory card reader which I use for my camera card and it used to come up with the Scanner and Camera Wizard each time I inserted the card. I've tried for 2 days with various setting with no success. Did Ewido delete something vital? I noticed some dll’s were deleted possibly in the system32 folder. Your help would be greatly appreciated.
    Regards, Glyn
  2. 2005/12/31
    charlesvar
    charlesvar Inactive Alumni
    Hello glynmaggs,
    If the System file checker doesn't work:
    Do you have System Restore enabled? If so, restore back to prior running Ewido.
    Ewido by defualt puts deleted items into quarentine - can be restored, and creates a log - there is an option to save as a Notepad file in the \Program Files\Ewido folder.
    Regards - Charles
  5. 2005/12/31
    glynmaggs
    Still struggling
    Thanks for contributions- I ran sfc /scannow successfully with no reported files missing, corrupted or restored. I’m afraid 3 days ago I was so annoyed with Ewido that I deleted the whole program and files so restoration is no longer possible. System restore to a date before Ewido also has no effect.
    The problem seems to be the inability to save my settings for the removeable (internal sd card reader) drive. If I right click on the drive and select autoplay I’m able to select "copy pictures…. Scanning wizard" and check the box "always do…" and this brings up the wizard perfectly just as it always did. However on exiting and coming back to autoplay the settings are lost.
    I’m also able to select properties, autoplay and select the actions for each type of media, again they are lost on exiting.
    So far I've spent most of the day with this one and running out of ideas and patience!!
    Regards, Glyn
  6. 2005/12/31
    McTavish
    McTavish Inactive
    charlesvar
    Then un do that Restore - this is a seperate problem. If indeed you did have infected .dll files, they are now back. And if you didn't, no harm done.
    Regards - Charles
  8. 2006/01/01
    glynmaggs
    No Autoplay
    Happy new year to all and thanks for the help again. I’ve followed the advice and run Autofix but still no luck with the card reader.
    The log from Autofix may throw some light.
    AutoFix [V5.2.3790.67]
    Time [2005-12-31 22:01:26]
    Microsoft Windows Version [5.1 (Service Pack 2) <2600>]
    Test [The Shell Hardware Detection service is running.] - Instance [N/A]:
    Result [AutoStart Setting]: OK
    Result [The Shell Hardware Detection service is running.]: OK
    Test [Policies] - Instance [G:\, Drive Type: 2]:
    Result [HKCU\...\Policies!NoDrives]: OK {Absent}
    Result [HKCU\...\Policies!NoDriveAutorun]: OK {Absent}
    Result [HKCU\...\Policies!NoDriveTypeAutorun]: OK {Present}
    Result [HKLM\...\Policies!NoDrives]: OK {Absent}
    Result [HKLM\...\Policies!NoDriveAutorun]: OK {Absent}
    Result [HKLM\...\Policies!NoDriveTypeAutorun]: OK {Absent}
    Result [Driver level policies]: OK {
    HKLM\...\Services\!Autorun (Absent) <Allows>
    HKLM\...\Services\\Parameters!Autorun (Absent) <Allows>
    HKLM\System\CCS\Enum\...!AlwaysEnable (Absent) <Not set>
    HKLM\System\CCS\Enum\...!AlwaysDisable (Absent) <Not set> }
    Test [Drive Notification] - Instance [G:\, Drive Type: 2]:
    Status: {
    01 00 01 00 00
    01 00 DF DF 5F
    DF 5F 5F 5F 5F
    DF DF 5F 5F 5F
    DF DF DF 5F 5F
    5F DF DF DF 5F
    5F DF 5F 5F 5F
    5F 5F 00 5F 5F
    5F 5F 5F CF CF
    5F 5F 5F 5F 01
    00 FF FF FF FF
    FF FF FF FF FF
    FF
    DT: [0xFFFFFFFF], CT: [0x00FFFFFF] }
    Result [Legacy Notification]: OK
    Result [AutoPlay V2 Notification]: OK {
    Service (Fired)
    Shell (Triggered) }
    Test [User Settings] - Instance [G:\]:
    Result [User preferences are set to the factory default (failure is OK).]: OK
    >> Required action: No problems were found -> None
    I had a look as suggested in the registry as follows with the SD Card labelled as G Drive
    ]HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    (Default) REG_SZ (value not set)
    NoDriveTypeAutorun REG_DWORD 0x00000091 (145)
    As another test, after connecting the camera via a cable to a USB port, I have the following log.
    Time [2006-01-01 08:31:02]
    Status: {
    01 00 01 00 00
    01 00 DF DF 5F
    DF 5F 5F 5F 5F
    DF DF 5F 5F 5F
    DF DF DF 5F 5F
    5F DF DF DF 5F
    5F DF 5F 5F 5F
    5F 5F 00 5F 5F
    5F 5F 5F CF CF
    5F 5F 5F 5F 01
    00 FF FF FF FF
    FF FF FF FF FF
    FF
    Service (Fired)
    Shell (Triggered) }
    >> Repair << [Removing user preferences...]
    >> Required action: The wizard found problems but cannot fix them -> None
    Perhaps the HKLM reg key set at always disable needs a tweek? I’m happy to edit in with regedit, if needed. It seems odd that my external HDD works ok when plugged into the same USB port as was occupied by the camera. I’ve re-formatted the card but still no joy. Even tried another SD card. Just realised it can't be the card as it works in my wife's laptop.
    Regards, Glyn
