Problem with Taskbar
Discussion in 'Windows XP' started by wXm, 2003/10/16.
  1. 2003/10/16
    wXm
    wXm Inactive Thread Starter
    Hello all
    can anyone tell me whats wrong with my taskbar? :confused: When ever i turn on my computer and when I move my mouse over the taskbar its not working. it looks like its still loading something then i restart and after i restart 3 or 4 times it MIGHT work fine. sometimes when i click something on taskbar for example, volume control like 3 times it won't open but after 2 or 3 mins it will open 3 times ... so sometimes its working but just slacking. any thing I can do to fix that?
    Thank you
    wXm,
  2. 2003/10/16
    That sort of behavior usually indicates the CPU is too busy to respond to your mouse clicks right then and waits until it has a little free time.
    If it goes on that long, something is wrong.
    - have you loaded new hardware or software recently?
    - does the same thing happen if you boot into safe mode?
    - have you run a full virus scan using current virus def files?
