Problem With Partition Margic 8
Discussion in 'Other PC Software' started by bazeze, 2005/05/13.
  1. 2005/05/13
    bazeze
    bazeze Inactive Thread Starter
    Hi
    I install partition margic 8.
    partition the hard drive,Then the PC need to restart.
    When it finish, the screen of death come up, now i cant start windows.
    Please I need help.
    If i can get windows to start may be i can remove the software.
    OS: Windows Xp service pack 2
    Regards
    Bazeze
  2. 2005/05/13
    Chuck_W
    Chuck_W Inactive
    Try booting into safe mode if possible. Then you can uninstall partition magic.
    r.leale Lifetime Subscription
    r.leale Well-Known Member
    Hi Bazeze,
    Try booting from the PM CD first to remove. Did you make the rescue discs when the installation suggested it?
    Roger
  5. 2005/05/15
    bazeze
    hi,
    I did not make rescure boot, But i make from other pc.
    I manage to Do partition but now,
    It Won't format. whenever i try to format it give error #49 cant write.
    when i try to format via dos, it format and complete, but then message appear, "enable to write BOOT" format termitated,
    Cant Boot in any form including safe mode
    regards
    Bazeze
  6. 2005/05/16
    bazeze
    hi
    now i found what the problem is,
    when ever i try to format, the antivirus wont late me,
    pls somebody help me before i loose it.
    really desparate.
    :mad:
