Resolved Problem with My Neighbourhood Places
Discussion in 'Windows XP' started by bschau, 2009/10/11.
  1. 2009/10/11
    bschau
    bschau Well-Known Member Thread Starter
    Hi, through trying to clean up my windows I managed to somehow create a problem for my self. I have Windows XP sp3
    I seemed to have deleted something that prevents me from opening the Properties when I right click on My Neighbourhood Places.
    What happens is that I get an error message come up that says;
    "This file does not have a program associated with it for performing this action. Create an association in the Folder Options control panel. "
    I also get the same message when I click on the My Neighbourhood Places Icon on the Start Menu page.
    B
  2. 2009/10/12
    Hi and welcome to the BBS,
    Do you see any file names mentioned in the error messages?
    Try looking in Event Viewer, right-click on My Computer, select Manage -> Event Viewer. Double click on the error to see more detail.
    bschau
    Hi Matt,
    Thanks for the quick response. I am in Canada and its Thanksgiving here so sorry for the delay in getting back to you.
    The error message just disappears if you click on it. I quoted the entire error message that appears.
    When I get a chance I will attempt a double click to see if I get any results.
    Also its the XP home not PRO
    I can get to the properties via the Control panel but am not able to via the desktop icons. Some ot the other Icons are acting the same way.
    Bruce:rolleyes:
  5. 2009/10/13
    If you are getting other errors/problems as well, it might be wise to do a System Restore to a point before you ran the cleaners. You might be back to square one with the cleaning, but be very careful what you do clean after that.
