Problem with My Docs redirection on Win 7 and SBS 2003
Discussion in 'Windows Server System' started by Iluvmydroid, 2012/07/03.
  1. 2012/07/03
    Iluvmydroid
    Iluvmydroid Inactive Thread Starter
    At my church we recently upgraded our presentaion computer and went from win xp to win 7. I initially set everything up as a local user since I did it at home and everything worked fine. After putting the computer on the domain and reinstall a couple apps, one won't work. It is online bible, not sure why it is called online because it doesn;t use the internet. When installing I choose custom install and tell it not to put any files in My Docs but apparently it still does, or at least tries to read it. I just get an error stating that online bible has stopped working. The problem details is:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: Olb.exe
    Application Version: 2.95.0.0
    Application Timestamp: 2a425e19
    Fault Module Name: Olb.exe
    Fault Module Version: 2.95.0.0
    Fault Module Timestamp: 2a425e19
    Exception Code: c0000005
    Exception Offset: 00005000
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: c460
    Additional Information 2: c46069f2dbac39cda35c96710b5b221c
    Additional Information 3: ca54
    Additional Information 4: ca54a954c99b393c4e46dd445078edb3
    Also an EAccess Violation
    Call stack:
    :01005000 [Olb.exe] System::__linkproc__ LStrAsg
    :011E630A [Olb.exe] Biblefil::ConvertFromModuleCode (Biblefil.pas, line 951)
    :011E763D [Olb.exe] Biblefil::TBibleCtl::FileSaveBibleControlEntry (Biblefil.pas, line 1307)
    :011E67ED [Olb.exe] Biblefil::TBibleCtl::DeleteEntry (Biblefil.pas, line 1112)
    :011E6CFA [Olb.exe] Biblefil::TBibleCtl::FileLoad (Biblefil.pas, line 1191)
    :011E89F6 [Olb.exe] Biblefil::TBibleCtl::GetHDPath (Biblefil.pas, line 1722)
    :011EA728 [Olb.exe] Biblefil::InitialBibleCtl (Biblefil.pas, line 2448)
    :0120122D [Olb.exe] Initial::InitialOLB (INITIAL.PAS, line 51)
    :01202F38 [Olb.exe] initialization (olb.dpr, line 232)
    :76B1339A [kernel32.dll]
    :77509EF2 [ntdll.dll]
    :77509EC5 [ntdll.dll]
    Modules:
    $01000000 (01000000,00001000,00202000) C:\Program Files (x86)\Bible\Olb.exe
    $76B00000 (76B00000,00010000,000D0000) C:\Windows\syswow64\kernel32.dll
    $774D0000 (774D0000,00010000,000D5C00) C:\Windows\SysWOW64\ntdll.dll
    Works fine as a local user but not on the domain. The only thing I figure is the My Docs redirection is causing the problem. Any ideas?? Is there a to not redirect it but still sync the files? The user is setup as roaming and offline files are turned on.
    I don't know much of anything at all about sbs 2003 but I am very computer savy and can figure most anything out.
