Problem With Macromedia Flash
Discussion in 'Other PC Software' started by DeadlyCreature, 2006/06/13.
  1. 2006/06/13
    DeadlyCreature
    DeadlyCreature Inactive Thread Starter
    I just disabled the Background Intelligent Transfer, and when I restarted the computer and started Internet Explorer; Homepage: http://www.sbc.yahoo.com/dsl/. It said Macromedia Flash wasn't installed, so I installed it again; nothing worked. I enabled BIT, but it still says the same thing.
  2. 2006/06/13
    Welshjim
    Welshjim Inactive
    DeadlyCreature--
    Sites that use Macromedia Flash usually require that ActiveX controls be permitted to run. The simplest way to do that is to put the site into your Trusted Sites (assuming you do trust it). Uncheck the box "Require Server Verification... "|OK|Apply|OK.
    Is this homepage new? Strange you would not have seen this before.
    DeadlyCreature
    I always had this homepage. I fixed that problem before by updating the Flash Add-On, but it does not work this time.
  5. 2006/06/13
    Welshjim
    Welshjim Inactive
    DeadlyCreature--Did you put the homepage site into Trusted Sites?
  6. 2006/06/13
    DeadlyCreature
    Yes, I have done that, but my problem is still not solved.
  7. 2006/06/13
    Welshjim
    Welshjim Inactive
    DeadlyCreature--Regrettably when I try to access http://www.sbc.yahoo.com/dsl/
    I am redirected to http://sbc.yahoo.com/ which is a page offering me SBC Internet Service.
    I see no indication that Flash is involved on the http://sbc.yahoo.com page.
    I understand you cannot use your internet service because of the message you see. Perhaps you should contact SBC. It would seem you are not getting the service you are paying for.
    P.S. Any reason why you disabled BIT?
  8. 2006/06/13
    DeadlyCreature
    It is not interfering with my service whatsoever. It just says Flash is not active on the home page.
  9. 2006/06/13
    Welshjim
    Welshjim Inactive
    DeadlyCreature--
    Guess I misunderstood.
    You have nothing to lose by contacting SBC, but if you do not want to, maybe just live with the message.
