Resolved Problem with Logitech wheel/pedals
Discussion in 'PC Hardware' started by Bucksone, 2009/07/29.
  1. 2009/07/29
    Bucksone
    Bucksone Well-Known Member Thread Starter
    I have a Logitech Formula Force GP steering wheel/pedals that I use to play racing games. The wheel connects to the computer through a USB port and the accelerator/brake pedals connect to the wheel with what I would call a telephone like cable. The computer sees and responds to input from the steering wheel but not from the pedals. I tried re-calibrating but it still didn't see the pedals. I will appreciate any suggestions.
  2. 2009/07/30
    Bucksone
    Thanks for the reply. The game in question is NASCAR 2003. I've been sucessfully using this wheel and pedals playing this game for a number of years. It just stopped working in the last week or so.
  5. 2009/07/31
    To save yourself time trying to troubleshoot it when it could be physically broken, you should set it up on another computer and see if you can make it work there.
    If you have installed drivers and software for it, try highlighting the drivers in Device Manager and uninstall it/them. Uninstall and reinstall the software. Check if there are updates or patches at Logitech.
    Look for information on the CD/DVD that came with it.
  6. 2009/07/31
    Bucksone
    Well, I took the pedal assembly apart last night and found broken wires. I got seven good years out of it, so I pitched it and bought a new one. Thanks for replying to my post.
  7. 2009/07/31
    Oh well.
    Thanks for letting us know.
