Solved Problem with Internet Security 2010
Discussion in 'Malware and Virus Removal Archive' started by cecelikeike, 2010/01/19.
  1. 2010/01/19
    cecelikeike
    cecelikeike Inactive Thread Starter
    [Resolved] Problem with Internet Security 2010
    I have the IS 2010 virus on a friends laptop, I see that you guys say to run DDS,I can the problem I am having is this, when I boot into safe mode, it goes to the desktop and when I try to run any software, it will give me only 60 seconds, to start anything, then it shuts down. I have to reboot several times, I feel like I am running in circles. Will I have time to run DDS before it shuts down? Thanks in advance for any help.
  2. 2010/01/19
    Download both tools listed below first (maybe even on good computer and move them to bad computer)...
    1. Please download and run the below tool named Rkill (courtesy of BleepingComputer.com) which may help allow other programs to run.
    There are 4 different versions. If one of them won't run then download and try to run the other one.
    Vista and Win7 users need to right click Rkill and choose Run as Administrator
    You only need to get one of these to run, not all of them. You may get warnings from your antivirus about this tool, ignore them or shutdown your antivirus.
    * Rkill.com
    * Rkill.scr
    * Rkill.pif
    * Rkill.exe
    * Double-click on the Rkill desktop icon to run the tool.
    * If using Vista or Windows 7 right-click on it and choose Run As Administrator.
    * A black DOS box will briefly flash and then disappear. This is normal and indicates the tool ran successfully.
    * If not, delete the file, then download and use the one provided in Link 2.
    * If it does not work, repeat the process and attempt to use one of the remaining links until the tool runs.
    * Do not reboot until instructed.
    * If the tool does not run from any of the links provided, please let me know.
    Once you've gotten one of them to run then try to immediately run the following.
    2. Please download ComboFix from [color= "Red"]Here[/color] or [color= "#FF0000"]Here[/color] to your Desktop.
    **Note: In the event you already have Combofix, this is a new version that I need you to download. It is important that it is saved directly to your desktop**
    • Please, never rename Combofix unless instructed.
    • Close any open browsers.
    • Close/disable all anti virus and anti malware programs so they do not interfere with the running of ComboFix.
    • Click on this link to see a list of programs that should be disabled. The list is not all inclusive. If yours is not listed and you don't know how to disable it, please ask.
    NOTE 1. If Combofix asks you to install Recovery Console, please allow it.
    • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
    • Double click on combofix.exe & follow the prompts.
    • When finished, it will produce a report for you.
    • Please post the "C:\ComboFix.txt" along with a new HijackThis log for further review.
    cecelikeike
    ok I downloaded all of the rkill, and this is what I got:
    This system is shutting down. Please save all work in progress and log off. Any unsaved changes will be lost. This sutdown was initiated by NT Authority/ System Remote Procedure Calll service terminated unexcpectantly.
    This file cannot be started. It is infected.
    Worm.Win32.Netsky has been detected. Run antivirus software.
    I tried to run it again, with combofix, and then this is what I got:
    Cannot find the file CFversionold. Creating system restore. Next options?
  5. 2010/01/20
    1. Download Dr.Web LiveCD: ftp://ftp.drweb.com/pub/drweb/livecd/minDrWebLiveCD-5.0.1.iso
    2. Download, and install free Imgburn: http://www.imgburn.com/index.php?act=download
    3. Using Imgburn, burn minDrWebLiveCD-5.0.1.iso to a CD.
    4. Make sure that the CD/DVD drive is set as the first-boot device. Adjust corresponding BIOS settings, if necessary.
    5. Insert Dr.Web LiveCD into the drive and restart computer.
    6. As loading starts, a dialogue window will pop up:
    7. Press Enter to continue with DrWeb-LiveCD (Default) mode.
    8. The operating system will detect all available disk drives automatically. It will also try to connect to the local network, if available.
    9. Check the disks or folders you want to scan, and click on Start.
    Dr.Web LiveCD user manual: ftp://ftp.drweb.com/pub/drweb/livecd/LiveCD-ru.pdf
  6. 2010/01/20
    cecelikeike
    Ok, I ran DrWeb and it got me to the point where now I can run windows malicious removal tool, and such. The problem I am still having is that, the IS2010 still pops up and runs a scan. I am running windows malicious removal tool right now. I am going to try and use rkill now with combofix. If it matters the computer at hand is a fujitsu p7230 netbook running XP home w/SP3
  7. 2010/01/20
    Good news then :)
    Don't bother with Windows malicious removal tool.
    Run Combofix as soon, as possible. Combo can be run in Safe Mode, if you need to.
  8. 2010/01/20
    cecelikeike
    Combo fix is running right now. So should this do the trick? I mean when I log on, I shouldn't see that "Your Computer is Infected sign" right? Thanks for your help. I really appreciate it.
  9. 2010/01/20
    We won't rush, or predict anything.
    At this point, we should be very happy, we made your computer bootable.
    It surely will take few scans to make sure your computer is clean.
  10. 2010/01/20
    cecelikeike
    Should I run combo fix a couple more times. I already ran it twice. and now I am installing AVG 9, then malware bytes and getting rid of norton. What else should I run?
  11. 2010/01/20
    Please, please, do ONLY what I ask you to do!
    My instructions say in big, red letters:
    Post Combofix log and do nothing else.
  12. 2010/01/20
    cecelikeike
    Oh yeah, sorry ok,how will i know when it is completely clean
  13. 2010/01/20
    When I tell you, it's clean, it'll be clean.
    Do not install anything, especially AVG.
  14. 2010/01/20
    cecelikeike
    Ok will do
  15. 2010/01/20
    So, I need that Combofix log.
  16. 2010/01/20
    cecelikeike
    ComboFix 10-01-20.04 - Administrator 01/20/2010 14:36:08.2.1 - x86 NETWORK
    Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1014.756 [GMT -10:00]
    Running from: c:\documents and settings\Administrator\Desktop\ComboFix.exe
    AV: Norton Internet Security *On-access scanning enabled* (Outdated) {E10A9785-9598-4754-B552-92431C1C35F8}
    FW: Norton Internet Security *enabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
    ((((((((((((((((((((((((( Files Created from 2009-12-21 to 2010-01-21 )))))))))))))))))))))))))))))))
    2010-01-20 23:19 . 2009-09-22 01:59 3101560 ----a-w- c:\documents and settings\Phillip\Application Data\Simply Super Software\Trojan Remover\rsw5.exe
    2010-01-20 22:57 . 2009-09-22 01:59 3101560 ----a-w- c:\documents and settings\Tracey\Application Data\Simply Super Software\Trojan Remover\tto1.exe
    2010-01-20 07:06 . 2010-01-20 07:06 -------- d-----w- c:\documents and settings\Administrator\Application Data\AVG8
    2010-01-20 06:46 . 2009-09-22 01:59 3101560 ----a-w- c:\documents and settings\Administrator\Application Data\Simply Super Software\Trojan Remover\mfb2.exe
    2010-01-20 06:04 . 2010-01-20 06:07 -------- d-----w- C:\22780eb913e083f7cba4e4
    2010-01-20 03:11 . 2009-09-22 01:59 3101560 ----a-w- c:\documents and settings\Phillip\Application Data\Simply Super Software\Trojan Remover\uyd1.exe
    2010-01-20 02:47 . 2010-01-20 02:47 -------- d-----w- c:\documents and settings\Phillip\Application Data\Malwarebytes
    2010-01-20 02:21 . 2010-01-20 02:22 -------- d-----w- C:\cb73ad1185a510e69b40a9e4
    2010-01-20 02:19 . 2010-01-20 23:09 -------- d-----w- c:\program files\VS Revo Group
    2010-01-20 02:14 . 2010-01-20 02:19 -------- d-----w- C:\49c064785cbf89db26dc
    2010-01-20 01:56 . 2010-01-20 01:56 -------- d-----w- c:\documents and settings\Administrator\Application Data\Bytemobile
    2010-01-20 01:30 . 2010-01-20 01:30 -------- d-----w- c:\documents and settings\Administrator\Application Data\Malwarebytes
    2010-01-20 01:30 . 2010-01-20 01:30 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
    2010-01-20 00:51 . 2010-01-20 00:51 -------- d-----w- c:\documents and settings\Phillip\Application Data\Simply Super Software
    2010-01-20 00:41 . 2010-01-20 00:41 -------- d-----w- c:\documents and settings\Tracey\Application Data\Simply Super Software
    2010-01-20 00:22 . 2010-01-20 23:25 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
    2010-01-20 00:15 . 2006-06-19 23:01 69632 ----a-w- c:\windows\system32\ztvcabinet.dll
    2010-01-20 00:15 . 2006-05-26 01:52 162304 ----a-w- c:\windows\system32\ztvunrar36.dll
    2010-01-20 00:15 . 2005-08-26 11:50 77312 ----a-w- c:\windows\system32\ztvunace26.dll
    2010-01-20 00:15 . 2003-02-03 06:06 153088 ----a-w- c:\windows\system32\UNRAR3.dll
    2010-01-20 00:15 . 2002-03-06 11:00 75264 ----a-w- c:\windows\system32\unacev2.dll
    2010-01-20 00:15 . 2010-01-20 03:08 -------- d-----w- c:\program files\Trojan Remover
    2010-01-20 00:15 . 2010-01-20 00:15 -------- d-----w- c:\documents and settings\All Users\Application Data\Simply Super Software
    2010-01-20 00:15 . 2010-01-20 00:15 -------- d-----w- c:\documents and settings\Administrator\Application Data\Simply Super Software
    2010-01-19 23:50 . 2010-01-19 23:50 -------- d-----w- C:\Temp
    2010-01-20 23:03 . 2009-12-13 07:37 -------- d-----w- c:\documents and settings\Phillip\Application Data\LimeWire
    2010-01-20 02:27 . 2009-11-22 02:39 -------- d-----w- c:\program files\IObit
    2010-01-18 20:50 . 2008-08-28 00:15 -------- d-----w- c:\program files\Common Files\Symantec Shared
    2010-01-18 08:45 . 2009-11-17 02:39 79488 ----a-w- c:\documents and settings\Tracey\Application Data\Sun\Java\jre1.6.0_17\gtapi.dll
    2010-01-13 20:26 . 2008-08-28 00:15 -------- d-----w- c:\documents and settings\All Users\Application Data\Symantec
    2009-12-15 00:09 . 2009-12-15 00:09 -------- d-----w- c:\documents and settings\All Users\Application Data\Norton
    2009-12-13 08:19 . 2009-02-17 06:09 -------- d-----w- c:\documents and settings\Phillip\Application Data\Apple Computer
    2009-12-06 00:08 . 2009-12-06 00:08 -------- d-----w- c:\documents and settings\Phillip\Application Data\IObit
    2009-11-22 02:39 . 2009-11-22 02:39 -------- d-----w- c:\documents and settings\Tracey\Application Data\IObit
    2009-11-20 18:25 . 2009-11-20 18:25 79144 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 9.0.2.25\SetupAdmin.exe
    "LightScribe Control Panel "= "c:\program files\Common Files\LightScribe\LightScribeControlPanel.exe" [2007-06-20 451872]
    [HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce]
    "NeroHomeFirstStart "= "c:\program files\Common Files\Ahead\Lib\NMFirstStart.exe" [2007-07-05 16168]
    "Symantec PIF AlertEng "= "c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [2008-01-30 583048]
    "SunJavaUpdateSched "= "c:\program files\Java\jre6\bin\jusched.exe" [2008-12-12 136600]
    [HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Bluetooth Manager.lnk]
    path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Bluetooth Manager.lnk
    backup=c:\windows\pss\Bluetooth Manager.lnkCommon Startup
    [HKLM\~\startupfolder\C:^Documents and Settings^Phillip^Start Menu^Programs^Startup^LimeWire On Startup.lnk]
    path=c:\documents and settings\Phillip\Start Menu\Programs\Startup\LimeWire On Startup.lnk
    backup=c:\windows\pss\LimeWire On Startup.lnkStartup
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ATSwpNav]
    c:\program files\Fingerprint Sensor\ATSwpNav -run [X]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Adobe Reader Speed Launcher]
    2008-06-12 12:38 34672 ----a-w- c:\program files\Adobe\Reader 9.0\Reader\reader_sl.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\AT&T Communication Manager]
    2007-12-21 16:43 33280 ----a-w- c:\program files\AT&T\Communication Manager\ATTCM.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\atchk]
    2007-03-05 05:43 404248 ----a-r- c:\program files\Intel\AMT\atchk.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}]
    2007-07-05 00:01 148776 ----a-w- c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ccApp]
    2007-01-10 05:59 115816 ----a-w- c:\program files\Common Files\Symantec Shared\ccApp.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
    2008-04-14 12:00 15360 ------w- c:\windows\system32\ctfmon.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HPDJ Taskbar Utility]
    2002-05-24 12:46 188416 ----a-w- c:\windows\system32\spool\drivers\w32x86\3\hpztsb05.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HPHmon04]
    2002-06-20 19:06 339968 ----a-w- c:\windows\system32\hphmon04.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HPHUPD04]
    2002-05-24 12:47 49152 ----a-w- c:\program files\HP Photosmart 11\hphinstall\UniPatch\hphupd04.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\igfxhkcmd]
    2005-11-03 08:22 77824 ----a-r- c:\windows\system32\hkcmd.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\igfxpers]
    2005-11-03 08:26 118784 ----a-r- c:\windows\system32\igfxpers.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IntelWireless]
    2007-07-25 23:30 974848 ----a-w- c:\program files\Intel\Wireless\Bin\iFrmewrk.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IntelZeroConfig]
    2007-07-25 23:32 823296 ----a-w- c:\program files\Intel\Wireless\Bin\ZCfgSvc.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
    2009-11-13 02:33 141600 ----a-w- c:\program files\iTunes\iTunesHelper.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LightScribe Control Panel]
    2007-06-20 22:49 451872 ----a-w- c:\program files\Common Files\LightScribe\LightScribeControlPanel.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\LoadFUJ02E3]
    2006-11-17 22:38 80688 ----a-w- c:\program files\Fujitsu\FUJ02E3\FUJ02E3.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\mxomssmenu]
    2007-09-07 00:53 169264 ----a-w- c:\program files\Maxtor\OneTouch Status\MaxMenuMgr.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\NeroFilterCheck]
    2007-07-05 00:20 161064 ----a-w- c:\program files\Common Files\Ahead\Lib\NeroCheck.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\osCheck]
    2007-01-14 07:11 771704 ----a-w- c:\program files\Norton Internet Security\osCheck.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\PSUtility]
    2006-10-30 07:37 136744 ----a-w- c:\program files\Fujitsu\PSUtility\TrayManager.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
    2009-11-11 09:08 417792 ----a-w- c:\program files\QuickTime\QTTask.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\RemoteControl]
    2006-11-14 05:33 52832 ----a-w- c:\program files\CyberLink\PowerDVD\PDVDServ.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Search Protection]
    2009-02-03 13:15 111856 ----a-w- c:\program files\Yahoo!\Search Protection\SearchProtection.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Share-to-Web Namespace Daemon]
    2002-04-17 17:42 69632 ----a-w- c:\program files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\swg]
    2009-03-24 04:45 68856 ----a-w- c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\TrojanScanner]
    2009-10-18 06:35 1070984 ----a-w- c:\program files\Trojan Remover\Trjscan.exe
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\YSearchProtection]
    [HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\services]
    "omniserv "=2 (0x2)
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecAntiVirus]
    [HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\SymantecFirewall]
    [HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
    "EnableFirewall "= 0 (0x0)
    "%windir%\\Network Diagnostic\\xpnetdiag.exe "=
    "c:\\Program Files\\Bonjour\\mDNSResponder.exe "=
    "c:\\Program Files\\iTunes\\iTunes.exe "=
    R3 FUJ02E3;Fujitsu FUJ02E3 Device Driver;c:\windows\system32\drivers\fuj02e3.sys [8/27/2008 4:56 PM 4864]
    S2 PowerSavingUtilityService;PowerSavingUtilityService;c:\program files\Fujitsu\PSUtility\PSUService.exe [10/29/2006 9:37 PM 63016]
    S2 UNS;Intel(R) Active Management Technology User Notification Service;c:\program files\Intel\AMT\UNS.exe [8/27/2008 2:25 PM 1489688]
    S3 ATTRcAppSvc;AT&T RcAppSvc;c:\program files\AT&T\Communication Manager\RcAppSvc.exe [12/21/2007 6:42 AM 113176]
    S3 MBAMSwissArmy;MBAMSwissArmy;\??\c:\windows\system32\drivers\mbamswissarmy.sys --> c:\windows\system32\drivers\mbamswissarmy.sys [?]
    *NewlyCreated* - COMHOST
    [HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
    2007-06-20 22:47 451872 ----a-w- c:\program files\Common Files\LightScribe\LSRunOnce.exe
    2009-09-21 c:\windows\Tasks\AppleSoftwareUpdate.job
    - c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 22:34]
    2009-12-01 c:\windows\Tasks\Norton Internet Security - Run Full System Scan - Tracey.job
    - c:\program files\Norton Internet Security\Norton AntiVirus\Navw32.exe [2007-01-14 09:09]
    mStart Page = hxxp://www.yahoo.com/?fr=fp-yma3
    uInternet Connection Wizard,ShellNext = hxxp://www.enigmasoftware.com/download_scanner/spyhunterS.exe
    LSP: bmnet.dll
    DPF: {A1662FB6-39BE-41BB-ACDC-0448FB1B5817} - hxxp://images3.pnimedia.com/ProductAssets/costcous/activex/v3_0_0_5/PhotoCenter_ActiveX_Control.cab
    DPF: {DEA6994F-3ED5-40BC-B5E3-0FD02411B1B4} - hxxp://www.costcophotocenter.com/upload/activex/v3_0_0_1/PhotoCenter_ActiveX_Control.cab?
    Rootkit scan 2010-01-20 14:38
    Windows 5.1.2600 Service Pack 3 NTFS
    scanning hidden processes ...
    scanning hidden files ...
    scan completed successfully
    hidden files: 0
    Completion time: 2010-01-20 14:40:09
    ComboFix-quarantined-files.txt 2010-01-21 00:40
    ComboFix2.txt 2010-01-21 00:31
    Pre-Run: 22,395,342,848 bytes free
    Post-Run: 22,381,359,104 bytes free
    WindowsXP-KB310994-SP2-Home-BootDisk-ENU.exe
    [Boot Loader]
    Timeout=2
    Default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
    [Operating Systems]
    c:\cmdcons\BOOTSECT.DAT= "Microsoft Windows Recovery Console" /cmdcons
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS= "Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    - - End Of File - - B954069C97DB49132096C85851355427
  17. 2010/01/20
    OK. I need a log from the original run, ComboFix2.txt located in C directory.
  18. 2010/01/20
    cecelikeike
    Broni I cant find the original, after I ran it the first time I ran it again, and that is all I see in the C directory.
  19. 2010/01/20
    cecelikeike
    2010-01-21 00:31:03 . 2010-01-21 00:31:03 568 ----a-w- C:\Qoobox\Quarantine\Registry_backups\MSConfigStartUp-smss32.reg.dat
    2010-01-21 00:31:03 . 2010-01-21 00:31:03 600 ----a-w- C:\Qoobox\Quarantine\Registry_backups\MSConfigStartUp-OmniPass.reg.dat
    2010-01-21 00:31:01 . 2010-01-21 00:31:01 628 ----a-w- C:\Qoobox\Quarantine\Registry_backups\MSConfigStartUp-Internet Security 2010.reg.dat
    2010-01-21 00:31:00 . 2010-01-21 00:31:00 692 ----a-w- C:\Qoobox\Quarantine\Registry_backups\MSConfigStartUp-Advanced SystemCare 3.reg.dat
    2010-01-21 00:30:15 . 2009-02-16 16:09:21 90 ----a-w- C:\Qoobox\Quarantine\D\AUTORUN.INF.vir
    2010-01-21 00:28:03 . 2010-01-21 00:37:55 11,296 ----a-w- C:\Qoobox\Quarantine\Registry_backups\tcpip.reg
    2010-01-20 06:25:12 . 2010-01-21 00:34:30 408 ----a-w- C:\Qoobox\Quarantine\catchme.log
    2010-01-18 20:51:17 . 2010-01-18 20:51:17 774 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\Microsoft\Internet Explorer\Quick Launch\Internet Security 2010.lnk.vir
    2010-01-18 20:51:17 . 2010-01-18 20:51:17 756 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Start Menu\Internet Security 2010.lnk.vir
    2010-01-18 20:51:17 . 2010-01-18 20:51:17 756 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Desktop\Internet Security 2010.lnk.vir
    2010-01-18 20:51:17 . 2010-01-18 20:51:08 1,462,784 ----a-w- C:\Qoobox\Quarantine\C\Program Files\InternetSecurity2010\IS2010.exe.vir
    2010-01-18 20:51:09 . 2010-01-20 07:14:31 0 ----a-w- C:\Qoobox\Quarantine\C\WINDOWS\system32\41.exe.vir
    2010-01-18 20:50:33 . 2010-01-20 07:14:29 2,931 ----a-w- C:\Qoobox\Quarantine\C\WINDOWS\system32\warning.html.vir
    2010-01-18 11:34:59 . 2010-01-18 11:34:59 1 ----a-w- C:\Qoobox\Quarantine\C\s.vir
    2010-01-18 11:32:09 . 2010-01-18 11:32:09 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGCE.tmp.vir
    2010-01-18 08:40:48 . 2010-01-18 08:40:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGC0.tmp.vir
    2010-01-17 19:25:55 . 2010-01-17 19:25:55 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGBF.tmp.vir
    2010-01-16 06:56:06 . 2010-01-16 06:56:06 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGBE.tmp.vir
    2010-01-15 06:36:30 . 2010-01-15 06:36:30 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB1.tmp.vir
    2010-01-14 09:29:55 . 2010-01-14 09:29:55 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGBD.tmp.vir
    2010-01-14 08:34:17 . 2010-01-14 08:34:17 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB0.tmp.vir
    2010-01-13 20:29:07 . 2010-01-13 20:29:07 1,295 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_7\images\1701_icon.png.vir
    2010-01-13 20:28:50 . 2010-01-13 20:28:50 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA6.tmp.vir
    2010-01-13 20:28:48 . 2010-01-13 20:28:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA2.tmp.vir
    2010-01-04 20:23:13 . 2010-01-04 20:23:13 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB6.tmp.vir
    2009-12-30 19:57:00 . 2009-12-30 19:57:00 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB5.tmp.vir
    2009-12-30 19:56:40 . 2009-12-30 19:56:40 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGAB.tmp.vir
    2009-12-30 19:48:58 . 2009-12-30 19:48:58 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA1.tmp.vir
    2009-12-26 21:50:22 . 2009-12-26 21:50:22 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGAA.tmp.vir
    2009-12-26 21:46:22 . 2009-12-26 21:46:22 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA0.tmp.vir
    2009-12-21 23:42:29 . 2009-12-21 23:42:29 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9F.tmp.vir
    2009-12-19 04:04:26 . 2009-12-19 04:04:26 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG183.tmp.vir
    2009-12-19 02:42:18 . 2009-12-19 02:42:18 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG179.tmp.vir
    2009-12-19 02:07:21 . 2009-12-19 02:07:21 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG146.tmp.vir
    2009-12-19 00:52:31 . 2009-12-19 00:52:31 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9E.tmp.vir
    2009-12-18 06:37:00 . 2009-12-18 06:37:00 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA4.tmp.vir
    2009-12-18 06:23:31 . 2009-12-18 06:23:31 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9D.tmp.vir
    2009-12-17 19:33:52 . 2009-12-17 19:33:52 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG97.tmp.vir
    2009-12-17 12:31:34 . 2009-12-17 12:31:34 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA7.tmp.vir
    2009-12-17 10:16:28 . 2009-12-17 10:16:28 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG94.tmp.vir
    2009-12-13 09:53:31 . 2009-12-13 09:53:31 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG93.tmp.vir
    2009-12-09 02:49:01 . 2009-12-09 02:49:01 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGBB.tmp.vir
    2009-12-09 02:48:38 . 2009-12-09 02:48:38 1,532 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB4.tmp.vir
    2009-12-08 00:16:57 . 2009-12-08 00:16:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGCC.tmp.vir
    2009-12-08 00:00:35 . 2009-12-08 00:00:35 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGBA.tmp.vir
    2009-12-07 14:50:45 . 2009-12-07 14:50:45 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9A.tmp.vir
    2009-12-07 00:34:35 . 2009-12-07 00:34:35 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGCB.tmp.vir
    2009-12-07 00:16:35 . 2009-12-07 00:16:35 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGC3.tmp.vir
    2009-12-07 00:14:26 . 2009-12-07 00:14:26 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGBC.tmp.vir
    2009-12-07 00:04:36 . 2009-12-07 00:04:36 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA9.tmp.vir
    2009-12-07 00:00:57 . 2009-12-07 00:00:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9C.tmp.vir
    2009-12-06 19:42:42 . 2009-12-06 19:42:42 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7F.tmp.vir
    2009-12-05 21:08:17 . 2009-12-05 21:08:17 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG91.tmp.vir
    2009-12-05 21:00:19 . 2009-12-05 21:00:19 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7E.tmp.vir
    2009-12-03 22:49:08 . 2009-12-03 22:49:08 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7D.tmp.vir
    2009-11-28 21:10:14 . 2009-11-28 21:10:14 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG98.tmp.vir
    2009-11-28 21:04:02 . 2009-11-28 21:04:02 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8E.tmp.vir
    2009-11-17 04:26:51 . 2009-11-17 04:26:51 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9B.tmp.vir
    2009-11-17 04:24:25 . 2009-11-17 04:24:25 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8B.tmp.vir
    2009-11-17 04:10:58 . 2009-11-17 04:10:58 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7C.tmp.vir
    2009-11-16 11:42:35 . 2009-11-16 11:42:35 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG92.tmp.vir
    2009-11-16 11:27:38 . 2009-11-16 11:27:38 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG88.tmp.vir
    2009-11-16 01:11:23 . 2009-11-16 01:11:23 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGAF.tmp.vir
    2009-11-15 23:55:21 . 2009-11-15 23:55:21 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG96.tmp.vir
    2009-11-15 21:51:23 . 2009-11-15 21:51:23 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7B.tmp.vir
    2009-11-14 10:03:51 . 2009-11-14 10:03:51 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG82.tmp.vir
    2009-11-14 09:45:29 . 2009-11-14 09:45:29 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG75.tmp.vir
    2009-11-11 02:26:34 . 2009-11-11 02:26:34 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8D.tmp.vir
    2009-11-11 01:12:20 . 2009-11-11 01:12:20 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG74.tmp.vir
    2009-11-10 23:37:55 . 2009-11-10 23:37:55 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG73.tmp.vir
    2009-11-09 23:18:13 . 2009-11-09 23:18:13 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG86.tmp.vir
    2009-11-08 22:50:59 . 2009-11-08 22:50:59 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6E.tmp.vir
    2009-11-06 22:56:38 . 2009-11-06 22:56:38 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG90.tmp.vir
    2009-11-06 22:35:31 . 2009-11-06 22:35:31 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6D.tmp.vir
    2009-10-24 04:45:37 . 2009-10-24 04:45:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6A.tmp.vir
    2009-10-22 21:24:51 . 2009-10-22 21:24:51 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7A.tmp.vir
    2009-10-22 10:13:16 . 2009-10-22 10:13:16 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB8.tmp.vir
    2009-10-22 07:23:01 . 2009-10-22 07:23:01 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG84.tmp.vir
    2009-10-21 18:30:18 . 2009-10-21 18:30:18 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG80.tmp.vir
    2009-10-21 18:28:37 . 2009-10-21 18:28:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG79.tmp.vir
    2009-10-21 18:21:52 . 2009-10-21 18:21:52 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG69.tmp.vir
    2009-10-19 05:17:48 . 2009-10-19 05:17:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB9.tmp.vir
    2009-10-19 03:49:27 . 2009-10-19 03:49:27 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGAE.tmp.vir
    2009-10-19 00:52:05 . 2009-10-19 00:52:05 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA5.tmp.vir
    2009-10-18 22:01:05 . 2009-10-18 22:01:05 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8A.tmp.vir
    2009-10-18 21:08:37 . 2009-10-18 21:08:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG78.tmp.vir
    2009-10-17 18:51:56 . 2009-10-17 18:51:56 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG67.tmp.vir
    2009-10-17 10:36:09 . 2009-10-17 10:36:09 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB7.tmp.vir
    2009-10-17 08:45:40 . 2009-10-17 08:45:40 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGAD.tmp.vir
    2009-10-17 08:22:44 . 2009-10-17 08:22:44 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG99.tmp.vir
    2009-10-17 06:47:33 . 2009-10-17 06:47:33 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG87.tmp.vir
    2009-10-17 05:41:51 . 2009-10-17 05:41:51 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG71.tmp.vir
    2009-10-17 04:53:00 . 2009-10-17 04:53:00 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG66.tmp.vir
    2009-10-15 10:42:15 . 2009-10-15 10:42:15 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGAC.tmp.vir
    2009-10-15 10:18:54 . 2009-10-15 10:18:54 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA3.tmp.vir
    2009-10-15 10:06:48 . 2009-10-15 10:06:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8C.tmp.vir
    2009-10-15 09:59:48 . 2009-10-15 09:59:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG81.tmp.vir
    2009-10-15 09:56:37 . 2009-10-15 09:56:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG77.tmp.vir
    2009-10-15 08:40:49 . 2009-10-15 08:40:49 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG64.tmp.vir
    2009-10-15 08:30:44 . 2009-10-15 08:30:44 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG5D.tmp.vir
    2009-10-13 09:30:50 . 2009-10-13 09:30:50 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG89.tmp.vir
    2009-10-13 08:10:36 . 2009-10-13 08:10:36 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG70.tmp.vir
    2009-10-13 07:42:14 . 2009-10-13 07:42:14 1,267 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_6\images\1045_icon.png.vir
    2009-10-13 07:41:57 . 2009-10-13 07:41:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG5C.tmp.vir
    2009-10-07 09:48:43 . 2009-10-07 09:48:43 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG68.tmp.vir
    2009-10-07 09:38:15 . 2009-10-07 09:38:15 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG5E.tmp.vir
    2009-10-07 09:37:10 . 2009-10-07 09:37:10 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG57.tmp.vir
    2009-10-06 23:58:35 . 2009-10-06 23:58:35 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG56.tmp.vir
    2009-09-30 05:46:48 . 2009-09-30 05:46:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG95.tmp.vir
    2009-09-30 05:36:25 . 2009-09-30 05:36:25 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG85.tmp.vir
    2009-09-30 05:26:03 . 2009-09-30 05:26:03 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG72.tmp.vir
    2009-09-30 03:15:17 . 2009-09-30 03:15:17 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG55.tmp.vir
    2009-09-26 19:35:44 . 2009-09-26 19:35:44 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG5B.tmp.vir
    2009-09-23 23:22:37 . 2009-09-23 23:22:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG76.tmp.vir
    2009-09-23 23:05:01 . 2009-09-23 23:05:01 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG61.tmp.vir
    2009-09-23 23:01:27 . 2009-09-23 23:01:27 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG54.tmp.vir
    2009-09-22 22:29:19 . 2009-09-22 22:29:19 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG65.tmp.vir
    2009-09-18 07:09:59 . 2009-09-18 07:09:59 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG63.tmp.vir
    2009-09-17 22:17:25 . 2009-09-17 22:17:25 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG58.tmp.vir
    2009-09-17 22:11:12 . 2009-09-17 22:11:12 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG50.tmp.vir
    2009-09-17 09:14:14 . 2009-09-17 09:14:14 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG5A.tmp.vir
    2009-09-17 08:54:36 . 2009-09-17 08:54:36 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG4F.tmp.vir
    2009-09-16 23:37:50 . 2009-09-16 23:37:50 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG47.tmp.vir
    2009-09-13 19:42:00 . 2009-09-13 19:42:00 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG46.tmp.vir
    2009-09-12 18:22:37 . 2009-09-12 18:22:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG45.tmp.vir
    2009-09-12 06:15:48 . 2009-09-12 06:15:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG53.tmp.vir
    2009-09-12 05:09:22 . 2009-09-12 05:09:22 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG41.tmp.vir
    2009-09-11 23:44:26 . 2009-09-11 23:44:26 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB3.tmp.vir
    2009-09-11 23:26:27 . 2009-09-11 23:26:27 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA8.tmp.vir
    2009-09-11 20:12:53 . 2009-09-11 20:12:53 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG60.tmp.vir
    2009-09-11 19:41:26 . 2009-09-11 19:41:26 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG48.tmp.vir
    2009-09-04 06:23:57 . 2009-09-04 06:23:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG40.tmp.vir
    2009-09-03 06:10:34 . 2009-09-03 06:10:34 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6C.tmp.vir
    2009-09-02 16:51:01 . 2009-09-02 16:51:01 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG39.tmp.vir
    2009-09-01 22:17:32 . 2009-09-01 22:17:32 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG62.tmp.vir
    2009-09-01 22:09:02 . 2009-09-01 22:09:02 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG44.tmp.vir
    2009-09-01 22:07:08 . 2009-09-01 22:07:08 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG38.tmp.vir
    2009-09-01 09:51:47 . 2009-09-01 09:51:47 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG4D.tmp.vir
    2009-09-01 09:40:44 . 2009-09-01 09:40:44 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG36.tmp.vir
    2009-08-29 10:25:19 . 2009-08-29 10:25:19 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG33.tmp.vir
    2009-08-28 09:47:26 . 2009-08-28 09:47:26 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG4B.tmp.vir
    2009-08-28 07:58:58 . 2009-08-28 07:58:58 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG29.tmp.vir
    2009-08-24 11:47:19 . 2009-08-24 11:47:19 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG4A.tmp.vir
    2009-08-24 11:45:56 . 2009-08-24 11:45:56 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG42.tmp.vir
    2009-08-24 11:43:03 . 2009-08-24 11:43:03 1,293 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\nclear.png.vir
    2009-08-18 22:03:10 . 2009-08-18 22:03:10 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG31.tmp.vir
    2009-08-17 08:28:40 . 2009-08-17 08:28:40 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8F.tmp.vir
    2009-08-17 08:04:12 . 2009-08-17 08:04:12 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG83.tmp.vir
    2009-08-17 01:43:11 . 2009-08-17 01:43:11 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG52.tmp.vir
    2009-08-12 06:09:37 . 2009-08-12 06:09:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG25.tmp.vir
    2009-08-07 07:13:49 . 2009-08-07 07:13:49 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6B.tmp.vir
    2009-08-07 07:08:52 . 2009-08-07 07:08:52 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG59.tmp.vir
    2009-08-07 05:40:58 . 2009-08-07 05:40:58 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG49.tmp.vir
    2009-08-07 05:40:19 . 2009-08-07 05:40:19 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG3F.tmp.vir
    2009-08-07 05:34:21 . 2009-08-07 05:34:21 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG2D.tmp.vir
    2009-08-07 05:30:59 . 2009-08-07 05:30:59 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG24.tmp.vir
    2009-07-21 09:01:57 . 2009-07-21 09:01:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG23.tmp.vir
    2009-07-20 21:20:24 . 2009-07-20 21:20:24 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG28.tmp.vir
    2009-07-15 00:46:24 . 2009-07-15 00:46:24 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG22.tmp.vir
    2009-07-14 08:47:58 . 2009-07-14 08:47:58 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG4E.tmp.vir
    2009-07-14 06:57:39 . 2009-07-14 06:57:39 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG2A.tmp.vir
    2009-07-06 19:14:04 . 2009-07-06 19:14:04 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG3E.tmp.vir
    2009-06-27 21:01:45 . 2009-06-27 21:01:45 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG3D.tmp.vir
    2009-06-27 21:00:45 . 2009-06-27 21:00:45 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG35.tmp.vir
    2009-06-27 20:54:48 . 2009-06-27 20:54:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG2C.tmp.vir
    2009-06-27 20:51:14 . 2009-06-27 20:51:14 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG20.tmp.vir
    2009-06-26 21:26:57 . 2009-06-26 21:26:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG37.tmp.vir
    2009-06-26 21:12:17 . 2009-06-26 21:12:17 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG30.tmp.vir
    2009-06-26 07:15:53 . 2009-06-26 07:15:53 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG1C.tmp.vir
    2009-06-16 09:45:26 . 2009-06-16 09:45:26 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG3A.tmp.vir
    2009-06-16 07:30:47 . 2009-06-16 07:30:47 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG1B.tmp.vir
    2009-06-11 03:36:49 . 2009-06-11 03:36:49 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG5F.tmp.vir
    2009-06-11 03:31:07 . 2009-06-11 03:31:07 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG4C.tmp.vir
    2009-06-11 01:29:38 . 2009-06-11 01:29:38 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG32.tmp.vir
    2009-06-11 01:23:16 . 2009-06-11 01:23:16 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG2E.tmp.vir
    2009-06-11 01:09:15 . 2009-06-11 01:09:15 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG1A.tmp.vir
    2009-06-04 08:05:08 . 2009-06-04 08:05:08 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG19.tmp.vir
    2009-05-21 06:48:59 . 2009-05-21 06:48:59 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG18.tmp.vir
    2009-05-17 10:50:11 . 2009-05-17 10:50:11 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG3B.tmp.vir
    2009-05-17 08:27:10 . 2009-05-17 08:27:10 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG34.tmp.vir
    2009-05-17 07:12:02 . 2009-05-17 07:12:02 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG27.tmp.vir
    2009-05-17 07:11:45 . 2009-05-17 07:11:45 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG1F.tmp.vir
    2009-05-17 07:09:10 . 2009-05-17 07:09:10 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG17.tmp.vir
    2009-05-17 05:00:30 . 2009-05-17 05:00:30 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGD7.tmp.vir
    2009-05-17 04:41:57 . 2009-05-17 04:41:57 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGC5.tmp.vir
    2009-05-17 04:27:53 . 2009-05-17 04:27:53 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB2.tmp.vir
    2009-05-17 03:16:11 . 2009-05-17 03:16:11 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6F.tmp.vir
    2009-05-17 02:41:01 . 2009-05-17 02:41:01 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG51.tmp.vir
    2009-05-16 23:46:37 . 2009-05-16 23:46:37 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG1D.tmp.vir
    2009-05-16 23:40:23 . 2009-05-16 23:40:23 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG14.tmp.vir
    2009-05-16 18:31:22 . 2009-05-16 18:31:22 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG13.tmp.vir
    2009-05-06 02:49:05 . 2009-05-06 02:49:05 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG2B.tmp.vir
    2009-05-02 20:24:40 . 2009-05-02 20:24:40 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG11.tmp.vir
    2009-05-01 08:51:06 . 2009-05-01 08:51:06 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG10.tmp.vir
    2009-04-30 04:36:51 . 2009-04-30 04:36:51 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGB.tmp.vir
    2009-04-29 22:52:07 . 2009-04-29 22:52:07 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG21.tmp.vir
    2009-04-29 19:28:16 . 2009-04-29 19:28:16 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGE.tmp.vir
    2009-04-25 10:39:40 . 2009-04-25 10:39:40 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG16.tmp.vir
    2009-04-24 06:15:34 . 2009-04-24 06:15:34 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGF.tmp.vir
    2009-04-17 20:54:48 . 2009-04-17 20:54:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG12.tmp.vir
    2009-04-17 11:26:40 . 2009-04-17 11:26:40 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG3C.tmp.vir
    2009-04-17 08:47:48 . 2009-04-17 08:47:48 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG26.tmp.vir
    2009-04-17 07:38:53 . 2009-04-17 07:38:53 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG9.tmp.vir
    2009-04-11 01:43:11 . 2009-04-11 01:43:11 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG1E.tmp.vir
    2009-04-06 19:49:54 . 2009-04-06 19:49:54 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG8.tmp.vir
    2009-04-05 01:17:04 . 2009-04-05 01:17:04 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG6.tmp.vir
    2009-03-26 03:17:38 . 2009-03-26 03:17:38 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGA.tmp.vir
    2009-03-24 04:46:10 . 2009-03-24 04:46:10 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG7.tmp.vir
    2009-03-23 08:23:20 . 2009-03-23 08:23:20 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG2F.tmp.vir
    2009-03-10 03:49:27 . 2009-03-10 03:49:27 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG43.tmp.vir
    2009-03-10 03:24:28 . 2009-03-10 03:24:28 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMG15.tmp.vir
    2009-02-19 08:53:12 . 2009-11-29 22:46:34 1,613 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\shower.png.vir
    2009-02-11 05:13:21 . 2009-02-11 05:13:22 1,511 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\clear.png.vir
    2009-02-11 00:34:20 . 2009-02-11 00:34:20 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGD.tmp.vir
    2009-01-15 00:19:09 . 2009-07-06 18:43:17 1,532 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\mcloud.png.vir
    2009-01-14 17:22:59 . 2009-11-15 02:12:42 1,301 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\alert-icon.png.vir
    2009-01-06 20:06:07 . 2009-01-06 20:06:07 0 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\IMGC.tmp.vir
    2009-01-01 22:40:40 . 2009-10-06 23:35:48 368 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\ToolbarSearch\ToolbarSearch.xml.backup.vir
    2008-12-15 14:33:24 . 2010-01-17 19:12:17 1,484 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\nmcloud.png.vir
    2008-12-14 00:56:57 . 2009-12-07 23:20:01 1,650 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\cloudy.png.vir
    2008-12-12 20:44:32 . 2008-12-12 20:44:32 382,384 ----a-w- C:\Qoobox\Quarantine\C\Program Files\Java\jre6\bin\jucheck.exe.vir
    2008-12-11 19:23:15 . 2008-12-12 23:27:01 1,164 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\alert.png.vir
    2008-12-11 19:23:15 . 2008-12-11 19:23:15 1,693 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\rain.png.vir
    2008-12-09 18:57:25 . 2010-01-04 20:29:32 1,532 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\pcloud.png.vir
    2008-12-09 18:37:16 . 2008-12-09 18:37:16 592 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_8\Button_8.xml.backup.vir
    2008-12-09 18:37:16 . 2008-12-09 18:37:16 592 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_8\Button_8.xml.vir
    2008-12-09 18:37:16 . 2010-01-13 20:29:08 760 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_7\Button_7.xml.backup.vir
    2008-12-09 18:37:16 . 2009-10-13 07:42:15 640 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_6\Button_6.xml.backup.vir
    2008-12-09 18:37:16 . 2010-01-13 20:29:08 760 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_7\Button_7.xml.vir
    2008-12-09 18:37:16 . 2009-10-13 07:42:15 640 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_6\Button_6.xml.vir
    2008-12-09 18:37:16 . 2009-08-24 06:04:29 1,392 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_5\Button_5.xml.backup.vir
    2008-12-09 18:37:16 . 2009-08-24 06:04:29 1,392 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_5\Button_5.xml.vir
    2008-12-09 18:37:16 . 2009-08-05 10:18:00 2,424 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_4\Button_4.xml.backup.vir
    2008-12-09 18:37:16 . 2009-08-05 10:18:00 2,424 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_4\Button_4.xml.vir
    2008-12-09 18:37:15 . 2009-08-24 06:04:29 3,296 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_3\Button_3.xml.backup.vir
    2008-12-09 18:37:15 . 2009-08-24 06:04:29 3,296 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_3\Button_3.xml.vir
    2008-12-09 18:37:15 . 2009-05-21 06:49:08 848 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_2\Button_2.xml.backup.vir
    2008-12-09 18:37:15 . 2009-05-21 06:49:08 848 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_2\Button_2.xml.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 176 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\configurator\configurator.xml.backup.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 176 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\configurator\configurator.xml.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 544 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_1\Button_1.xml.backup.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 544 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_1\Button_1.xml.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 3,392 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_0\Button_0.xml.backup.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 3,392 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Button_0\Button_0.xml.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 1,168 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\contextMenu\contextMenu.xml.backup.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 1,168 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\contextMenu\contextMenu.xml.vir
    2008-12-09 18:37:15 . 2010-01-18 20:53:00 224 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\TimerManager\TimerManager.xml.backup.vir
    2008-12-09 18:37:15 . 2010-01-18 20:53:00 224 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\TimerManager\TimerManager.xml.vir
    2008-12-09 18:37:15 . 2010-01-13 20:29:08 448 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Updater\Updater.xml.backup.vir
    2008-12-09 18:37:15 . 2010-01-13 20:29:08 448 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Updater\Updater.xml.vir
    2008-12-09 18:37:15 . 2009-10-06 23:35:48 368 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\ToolbarSearch\ToolbarSearch.xml.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 528 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\products\products.xml.backup.vir
    2008-12-09 18:37:15 . 2008-12-09 18:37:15 528 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\products\products.xml.vir
    2008-12-09 18:37:14 . 2008-12-09 18:37:14 22,424 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\toolbar.xml.backup.vir
    2008-12-05 22:35:40 . 2010-01-18 21:01:07 23,080 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\toolbar.xml.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,155 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\BrowserSearch\alot_search_defend.html.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 2,376 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_0\images\alot_logo_button.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,818 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_0\images\alot_logo_button.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_1\images\alot_search_button.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,427 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_1\images\alot_search_button.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,894 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_2\images\default_1002_alot_videos_videosearch.bmp.vir
    2008-12-05 22:35:40 . 2009-05-21 06:49:08 1,242 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_2\images\default_1002_alot_videos_videosearch.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_3\images\default_1042_alot_video_vault.bmp.vir
    2008-12-05 22:35:40 . 2009-08-24 06:04:29 1,238 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_3\images\default_1042_alot_video_vault.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\default_1007_alot_weather_widget.bmp.vir
    2008-12-05 22:35:40 . 2010-01-17 19:12:34 1,209 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_4\images\default_1007_alot_weather_widget.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_5\images\default_1043_alot_video_editing.bmp.vir
    2008-12-05 22:35:40 . 2009-08-24 06:04:29 1,355 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_5\images\default_1043_alot_video_editing.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_6\images\default_1045_alot_rea_laughs.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,205 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_6\images\default_1045_alot_rea_laughs.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_7\images\default_1602_alot_mrkt_livinghealthy.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 976 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_7\images\default_1602_alot_mrkt_livinghealthy.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,896 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_8\images\default_1530_alot_mrkt_simplyhired.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 826 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Button_8\images\default_1530_alot_mrkt_simplyhired.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 2,376 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\contextMenu\images\alot_logo_button.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,818 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\contextMenu\images\alot_logo_button.png.vir
    2008-12-05 22:35:40 . 2010-01-17 19:12:35 144 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\domains.dat.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 6,579 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\alot_brand.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 2,867 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\alot_splitter.png.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 4,808 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\spinner.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 630 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_bottom.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,286 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_btnclose0.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,286 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_btnclose1.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,110 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_caption.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 9,654 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_error_bg.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 1,558 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_error_close.bmp.vir
    2008-12-05 22:35:40 . 2008-12-05 22:35:40 3,626 ----a-w- C:\Qoobox\Quarantine\C\Documents and Settings\Tracey\Application Data\alot\Resources\Shared\images\widget_error_icon.bmp.vir
    2008-09-24 01:08:38 . 2007-03-08 05:10:09 991,232 -c--a-w- C:\Qoobox\Quarantine\C\WINDOWS\system32\dllcache\ieframe.dll.mui.vir
    2008-08-28 02:51:33 . 2008-08-28 02:51:33 13,864 ----a-w- C:\Qoobox\Quarantine\C\WINDOWS\AegisP.inf.vir
  20. 2010/01/20
    That will do.
    I can see Norton listed in Combofix as being outdated. What's the situation here?
    Is it some trial no longer used?
  21. 2010/01/20
    cecelikeike
    cecelikeike Inactive Thread Starter
    Yeah,
