Problem with Internet Explorer
Discussion in 'Internet Explorer & Microsoft Edge' started by infinitiX, 2004/01/05.
  1. 2004/01/05
    infinitiX
    infinitiX Inactive Thread Starter
    I cannot log into any online e-mail sites. This includes Sympatico, Hotmail and Yahoo and when I press smilie shortcut buttons on boards, they don't put the smilie onto my messege. When I open Internet Options, there is no Advanced tab present anymore.
    Also (unrelated to IE) when I open Control Panel, all the icons are all shifted to the left in another window. When I open Add/Remove Programs, the box is litterally empty except for the grey border on the side and the caption on the top.
    Thanks for your help :D
  2. 2004/01/05
    aleekat
    aleekat Inactive
    What version of IE?
    Did you downloaded/install/uninstall anything recently?
    Have you done a full virus scan?
    Housecall
    infinitiX
    I think it's IE6 (the one the comes standard with Windows 2000)
    I did a full virus scan 2 days ago with Panda Antivirus and I recently uninstalled Norton 2004. The Advanced tab in the Internet Options has been gone for a while though. And I just figured out that it's not just the smilies, I can't press any board buttons at all.
  5. 2004/01/05
    Please use a meaningful thread title as Rule #3 states.
    noahdfear
    noahdfear Inactive
    Do you use Spybot and AdAware? If not, download them both and after installing (reboot after each install) update their files. (I've found it necessary to close Spybot after d/l updates then reopen for them to install, though I can't say you will have to) Run spybot first. Delete all they find.
    Should probably also run CWShredder. The d/l link is near the bottom of the page.
  7. 2004/01/05
    infinitiX
    Thanks the CWShredder fixed up the Advanced tab but I still can't access online e-mail sites or get any of the board butons to work.
  8. 2004/01/05
    noahdfear
    noahdfear Inactive
    Did you by chance use the immunize feature in Spybot? If so, turn it off.
    What Operating System do you have?
  9. 2004/01/05
    infinitiX
    Windows 2000
  10. 2004/01/05
    noahdfear
    noahdfear Inactive
    OK, totally disregard my question about spybots immunize. My mind was on something else. :rolleyes:
    Regedit
    HKCU\Software\ Policies\ Microsoft\ Internet Explorer\Restrictions
    If there is an entry 'NoNavButtons' change it's value to '0'
  11. 2004/01/05
    infinitiX
    Nope, no option on that. As much as I know, I can't run any java scripts.
  12. 2004/01/07
    noahdfear
    noahdfear Inactive
    In tools>options>advanced what Java are you using? And under security>custom what permissions?
  13. 2004/01/07
    Lonny Jones
    Lonny Jones Inactive Alumni
    can you use the javascript links at the top right of this page ?
    Norton internet security 004 ?
    Did you install update and scan with Spybot and AdAware?
    You might try these sites to test the browser,, please tell us of any problems
    Jason Levine's Toolbox Browser Security Tests: http://www.jasons-toolbox.com/BrowserSecurity/
    Welcome to the BrowserTune2000 (BT2K) Site_ (Fred Langa): http://www.browsertune.com/bt2kfast/
    Lonny
  14. 2004/01/08
    infinitiX
    I'm kinda embarassed to say this but all I had to do was to run Scan Disk :p Well everything's alright now.
    Thanks for your help though, you were all really helpful :D
