Problem with "Improve Boot Performance"
Discussion in 'Windows XP' started by fredc, 2002/08/06.
  1. 2002/08/06
    fredc
    fredc Inactive Thread Starter
    Hi
    I used "Improve Boot Performance" for winXP and now I can`t use my PC anymore.
    The problem is that it boots but the desktop doesn`t show up, the process stops even before the welcome message. How can I fix this? Can`t use "Safe Mode" eather.
    Please help!
  2. 2002/08/07
    Eran
    Eran Inactive
    Not sure what you mean by "Improve Boot Performance" did you use bootviz?
    Anyway, did you try yo boot to last known good configuration?
    You can also try a repair instalation.
    Eran,
    fredc
    Yes I mean bootvis.
    Last known good configuration boot has no effect.
    I think a repair instalation is possible only if you get to windows.
    What files does bootvis effect because the only things I can do is change BIOS settings and use dos commands with a startup disc?
    Alredy played with BIOS settings but no effect and tried to find some clues about bootvis changes through dos.
  5. 2002/08/07
    Eran
    Eran Inactive
    reapair instalation is done by booting from the WXP CD, and choosing repair from the options.
    Eran,
