Problem: Template keeps sending
Discussion in 'Firefox, Thunderbird & SeaMonkey' started by robser99, 2012/01/28.
  1. 2012/01/28
    robser99
    robser99 Inactive Thread Starter
    Hello,
    I have managed to create a template for autoreply, and have also created a Filter in order to use it when receive certain mails, but somewhere it goes wrong because every time that I do a Send/Receive, the same incoming mails will be sent a new autoreply again and again???
    Any Idea what is the good Filter setup for this problem?
    Thanks very much!
    Apply Filter when = Checking Mail
    Match all of the Following
    Subject contains = "My text "
    then perform
    Reply with Template = "My Template "
  2. 2012/01/29
    robser99
    Almost ok
    Well, I'll answer myself, as I have resolved part of the problem.
    It was caused by the fact that I tested with autoreply to an account of myself that was also with an auto-forward.
    Now the only small item left is:
    In the subject header of the autoreply with the template, The subject of the original received mail is quoted like "(was: original subject)"
    How can I change that, or at least eliminate the "was:" part of it??
    Thanks again
