Windows Vista Problem: standby = logout
Discussion in 'Legacy Windows' started by Oddish, 2007/12/17.
  1. 2007/12/17
    Oddish
    Oddish Inactive Thread Starter
    I've just upgraded from XP to Vista on my home theater PC and I'm having problems with standby mode. When I try to put the computer in standby the screen (tv) goes black and everthing spins down as it should. But a second later, the computer starts up again and I'm presented with the login screen. Does anyone have any ideas about what could be causing this?
  2. 2007/12/17
    Some applications like Email if its open can cause this.
    Oddish
    It has to be something else since no applications are running when I put the computer to sleep. And it's not that I'm logged out (my mistake), the computer just wakes up directly after I try to put it to sleep. The login screen was just there because I had checked "require password on wakeup" (or something similiar).
  5. 2007/12/19
    sparrow
    sparrow Inactive
    Agree with Steve R Jones. Suggest you download winpatrol.exe (just type it in google to find it) and rt-clk the icon on the taskbar after it's installed and choose display startup info and disable or stop one by one the processes running in the background, especially the non-windows ones, till the computer stays asleep.
    Keep winpatrol. It's good antispyware too.
