Problem Slipstreaming XP Pro Corp & Sp2
Discussion in 'Windows XP' started by Rubber Eye, 2004/09/16.
  1. 2004/09/16
    Rubber Eye
    Rubber Eye Inactive Thread Starter
    After following the instructions at the following link (http://www.windows-help.net/WindowsXP/winxp-sp2-bootcd.html) to slipstream sp2 into xp, I've run into the following problem.
    The sp2 files are extracted but instead of running the service pack 2 wizard to intergrate the files i get a list of 'Available Switches' with an ok button at the bottom, after clicking on that nothing happens and I get no confirmation of the intergration, I have checked & double checked the command line for errors and there is none, also surely if the service pack extracts the files the command line is correct.
    Any help would be great on this matter
    SP2 downloaded directly from ms and if i run it on its own it starts the wizard correctly
  2. 2004/09/16
    Do you know if the OS was installed using Sysprep? If so, that can cause some strange issues.
    Rubber Eye
    No i did a clean install of xp from cd
  5. 2004/09/20
    irdreed
    irdreed Inactive
    IamKhayman
    IamKhayman Inactive
    Intergrate vs Integrate
    Made the same error myself here. Drop the R in INTERGRATE and make it INTEGRATE, that should take care of it.
