Problem slipstreaming Windows XP pro and sp2
Discussion in 'Windows XP' started by lnjr, 2008/06/11.
  1. 2008/06/11
    lnjr
    lnjr Inactive Thread Starter
    Hello,
    I have been trying to create a slipstreamed Windows XP CD with SP2. I followed the directions at eldergeek.com and had problems so then i tried the directions at winsupersite.com with the same results.
    When I get to the step where you combine XP with SP2 I get an error message stating that the service pack cannot be integrated into a destination that also has integrated software updates and to consult service pack documentation for details about supported integration scenarios.
    Any ideas or suggestions would be Greatly Appreciated.
    TIA
    lnjr,
  2. 2008/06/11
    mflynn
    mflynn Inactive
    Unfortunately you cannot slipstream your CD, which is clearly an OEM with SP2 .....
    From here .....
    http://www.helpwithwindows.com/techfiles/slipstreaming-XP-sp2.html
  5. 2008/06/11
    Mike
    It sounds like an OEM CD - not possible according to Arie's article. Can it be done with Autostreamer ?
  6. 2008/06/11
    mflynn
    mflynn Inactive
    10-4 Pete!
    EDIT: No Autostreamer can't either!
    I missed that!
    Mike
