problem in outlook express active x
Discussion in 'Internet Explorer & Microsoft Edge' started by navendukumar, 2002/05/10.
  1. 2002/05/10
    navendukumar
    navendukumar Guest Thread Starter
    I am facing unique problem in outlook express 6
    when i click on icon it giveds message that active x has prevented in loading the page please contact system administrator and fater that outlook express hange and I have to restart the machine
    please help me with solution
    email me on navendus@yahoo.com
    regards
  2. 2002/05/11
    bobmc32
    bobmc32 Well-Known Member
    A FWIW
    navendukumar
    You might give this a go while you wait for more knowlegeable persons than I to reply. Check on security settings in IE. In IE click tools>Internet options>click Security tab and then check what you have enabled/disabled. Your Active X choices are here for you to choose, I believe. As said, you might want to wait for more input.
