problem in outlook 6.0 not able to connect internet
Discussion in 'Internet Explorer & Microsoft Edge' started by navendukumar, 2002/05/01.
  1. 2002/05/01
    navendukumar
    navendukumar Guest Thread Starter
    Dear sir
    please help me with solution I am not able to connect directly to internet when I click on out 6.0 it should dial automatically even after using default connection the problem is not solved
    regards
  2. 2002/05/28
    eddie5659
    eddie5659 Inactive
    Hiya
    Lets try a general cleanup first
    Go to Tools | Internet Options. General tab. Under Delete Files, delete offline content. Also, clear the History.
    Content tab, under AutoComplete, clear Forms and Passwords.
    Advanced tab, under Browsing, look for Enable Insta on Demand. Untick.
    Under Security, look for Empty Tempory Internet... Tick.
    Apply and OK
    Go to Find Files and type in cookie. When found, open the folder, and delete all the cookies found. You won't be able to delete the .dat file found.
    For this, go here and get the Spider:
    http://www.fsm.nl/ward/
    (original URL replaced by moderator)
    Go to Run and type MSINFO32
    On the left choose Software Enviroment, then Startup Programs. Copy/paste the list here.
    Also, go here and download AddAware http://tomcoyote.com/lsindex.html
    Download and run, ensuring that Deep Registry scan is enabled. Remove all except any references to Web3000 or new.net. If you're unsure, copy/paste the list here.
    Also, whilst you're there, download and install RefUpdate to get the latest updates. Just click Connect.
    Regards
    eddie
    brett
    brett Inactive Alumni
    Text deleted.
