Printing Issue
Discussion in 'Windows 7' started by flynempire, 2010/07/06.
  1. 2010/07/06
    flynempire
    flynempire Well-Known Member Thread Starter
    Hello, I cannot print to a PhotoSmart C4680.
    Customer has a 2 PC network. One machine uses Windows 7 Pro 64-bit and the other uses Windows XP Pro 32-bit.
    The printer is attached to the XP machine and is shared. With the Win 7 machine I can see the printer thru the network, can connect to it and add it. I downloaded the correct driver for this unit.
    It does show up in printers and devices. The problem is every time I go to print, it says print failed. No matter what I do printing fails.
    Is this an issue with the 64-bit and 32-bit? HP support sent me a link to the basic driver. I recall I downloaded a 64-bit driver and that did not work either.
  2. 2010/07/06
    Whats the error in Windows log files ?
    flynempire
    I did not look in there. Never thought of that. Is it possible that 32-bit and 64-bit printing is an issue here?
  5. 2010/07/06
  6. 2010/07/06
    flynempire
    Hey thanks a lot! The article was awesome and makes total sense. I never realized this before.
    I will make time to go by their office and do this for them. I have saved the article and print it later.
    I will post my results and then if successful we can close this thread.
    Thanks,
    Mike
  7. 2010/07/06
    flynempire
    Hi I tried the article but unfortunately I was not able to get it to work.
    The printer is connected to and shared from the XP Pro. I went into sharing and then Additional Drivers. The problem is inside that window there is no way to add a driver from disk.
    It shows a few options and x64 was already selected. Is there anything else to try? I really am determined to make this work.
  8. 2010/07/06
    What do the Windows Logs in Win7 machine say ?
  9. 2010/07/07
  10. 2010/07/07
    flynempire
    Hello, yes I have the most recent drivers. I forgot to check the logs when I was there I will write that down for next time.
    I have an idea and let me know if this could work. Both PC's are in the same office across from each other. What if I physically took the printer off the XP machine and connected it directly to the Win 7 PC. I would then install the drivers on it and do a test print.
    Then install it back in the XP Pro machine. Could I then change the port in the Win 7 machine and point it to the XP machine and have it print that way?
  11. 2010/07/07
    It may or may not but it would certainly indicate if you are using the correct drivers or not.
  12. 2010/07/12
    flynempire
    I checked with the Event Logs and the only thing I have seen is failed to install driver on July 6th. I am going to connect the printer locally and then change the port to reflect the other PC.
  13. 2010/07/13
    flynempire
    I got it to work! I physically removed the printer from the XP machine and connected to Win 7 machine.
    I installed the basic driver and then proceed to do a test print. Once that was done and I installed it back in the XP machine.
    Finally I added a network printer and once it found the HP connected to XP machine I clicked add and it installed without a problem. The big test was printing so I did a test print and it worked. I then proceeded to print from Word, IE, etc.. It all worked.
    I am very glad this is resolved. It seems when adding locally, the correct driver is always there so even though I added it thru the network, it still uses the driver and not the one on the other PC. I hope this can help anyone with this problem.
