printer problems...
Discussion in 'Internet Explorer & Microsoft Edge' started by XtremeRunnerARS, 2004/01/24.
  1. 2004/01/24
    XtremeRunnerARS
    XtremeRunnerARS Banned Thread Starter
    i cannot print ANYTHING from the internet. It says "an error occured during the operation" When i go to add a printer in my printer folder, i click add new printer, nothing happens
    i am using xp pro
    HELP ME!!!
  2. 2004/01/24
    aleekat
    aleekat Inactive
    Most printer makers don't want you to use the add printer wizard. Check your paperwork, and uninstall/reinstall your printer and software. Check for updated drivers at your manufacturer's site.
    XtremeRunnerARS
    I can print in any other application, but anything online gives me that problem
  5. 2004/01/28
    irdreed
    irdreed Inactive
  6. 2004/01/28
    XtremeRunnerARS
    Neither of those suggestions worked...but thanks anyways. The error says exactly this: "An error occurred during this operatoin. "
    On page setup, it had a printer button. I clicked that, and my HP deskjet970Cxi was there, and i set it there but it gave me the same error. How does it remember the printer but i cant add it and it isnt there in the printers folder??
    any other suggestions?
    It is the newest version of IE
  7. 2004/01/28
    aleekat
    aleekat Inactive
    Did the printer work properly before?
    Have you installed anything recently?
    Maybe run restore to a date predating the problem?
    HPs are very perticular how they get installed. Just a quick look at the HP site, printer NOT to be connected when running the software to install.
    HP
  8. 2004/02/03
    XtremeRunnerARS
    Thanks for your efforts, but the problem isnt my printer
    O well
  9. 2004/02/03
    irdreed
    irdreed Inactive
    XtremeRunnerARS
    Explorer remembers the last printer installed. I know you said you click add printer and nothing happens, but from my experience with my HP printers, you have to completely uninstall all Hp printer's files and folders Before adding another one or doing a new installation.
    From what I've read of your description, it seems to me somehow a nothing printer got installed and that's what the I.E. sees, No Printer.
    Did you try either of my last post suggestions? if so what were the results??
  10. 2004/02/05
    irdreed
    irdreed Inactive
    XtremeRunnerARS
    nope....
    i think i'm going to back up what i need and reload windows xp
    my laptop has all kinds of problems
