Print scr
Discussion in 'Windows XP' started by Sand Crab, 2002/05/21.
  1. 2002/05/21
    Sand Crab
    Sand Crab Inactive Thread Starter
    'print scr' on XP key board does not function. Is this a normal problem, can other users print page on screen?
  2. 2002/05/21
    Paul
    Paul Inactive
    Print screen should work unless you have a crook keyboard?
    After hitting print screen open a compatible programme such as Word and then right click and select paste.
    BTW Alt+print screen will capture only the active screen.
    Works in Word pad, Paint progs. and other Word processor progs, even powerpoint.
    Paul
    Paul,
    Rancher
    Rancher Inactive
    print screen
    Great answer Paul!
    SmithC004 you can also paste into your fav viewer such as IrFanview & Xnview. Adobe uses the "Import from clipboard" for this feature. That print screen works fine in my WinXP:)
