Print banners with XP
Discussion in 'Windows XP' started by Nickhm, 2002/12/13.
  1. 2002/12/13
    Nickhm
    Nickhm Inactive Thread Starter
    Windows XP Pro will not print banners on continuous banner paper as 98 did. Any ideas:confused:
  2. 2002/12/14
    Daizy
    Daizy Inactive
    Hi Nickhm
    Welcome to the boards.
    Wouldn't this have to do with your printer software, more than Windows XP? Is there a chance your printer driver was updated?
    Daizy
    Daizy
    Daizy Inactive
    Hi again Nickhm
    Thank you for the note. I'm not sure what to advise you. But it does indeed sound like you lost the ability to do banner printing with the XP driver. Have you tried the 98 driver? ?
    Daizy
  5. 2002/12/16
    Daizy
    Daizy Inactive
    Hi once more Nickhm
    Have we scared you off posting to the boards? :eek:
    Forgive my ignorance, as I'm not using XP......... but you said in your note that the 98 driver doesn't work? What happens when you try to use it?
    Daizy
  6. 2002/12/17
    Nickhm
    Hello Daisy,
    On Windows XP it will ONLY let you use drivers et. which are compatible with XP, If you try to use things whic are not kosher they will not install.
    Thank You for your input on this.
