Preview pane does not work???
Discussion in 'Legacy Windows' started by Marv6, 2014/10/31.
  1. 2014/10/31
    Marv6 Lifetime Subscription
    Marv6 Well-Known Member Thread Starter
    Seem to have all of the correct settings as in under view preview pane is turned on, but, I currently cannot get it to work when I point to documents or jpg files. I must have changed something to keep it from working. Have checked websites for solution and even installed a reg file to turn it on, but, it still does not work. Any suggestions would be appreciated. Thanks.:mad:
  2. 2014/10/31
    Evan, thanks already checked these suggestions, but, even with preview pane enabled nothing happens when I point to the document with the mouse??? It did work, but, I must have changed some of the folder settings and now I cannot get it to work. In folder options I have show preview handlers in preview pane checked. Maybe there is some other setting that is preventing this in folder options? Maybe a mouse setting is wrong? Any other suggestions?
    Marvin
  5. 2014/11/01
    Evan, found the problem. Actually, there was no problem. I did not have the window open wide enough to see the previews or the details. I spend about 3 hours trying to correct a problem that did not exist!!!
  6. 2014/11/01
    Thanks for letting me know. Glad you found what you needed to correct. :)
